Error JLINKARM_DLL_ERROR when using Power Profiler
I am getting an error in the Power Profiler ppk.py when it is starting. The error occurs on the first call to nrfjprog.rtt_read. The error is JLINKARM_DLL_ERROR, which is -102.
(Updated) I wrote a similar small Python program to test pynrfprog and I find that the rtt_is_control_block_found() is always returning False.
I am using the software versions specified in the PPK User Guide:
  • Python 2.7.12 (32 bit)
  • nRF5x Command Line Tools (which installs Segger JLink 5.12g)
  • Python packages as installed by 'python_packages.bat', specifically pynrfjprog 9.0.0
I have programmed the DK with PPK_v1_0_0.hex using flash_pkk.py
Here is the cutdown program that fails to find the rtt control block:
import libs.rtt as rtt
import time
from pynrfjprog import API
JLINK_PRO_V8    = 4000
# Always try to have highest speed
JLINK_SPEED_KHZ = JLINK_PRO_V8
nrfjprog = API.API('NRF52')
nrfjprog.open()
nrfjprog.connect_to_emu_without_snr(jlink_speed_khz=JLINK_SPEED_KHZ)
nrfjprog.sys_reset()
nrfjprog.go()
nrfjprog.rtt_start()
time.sleep(1)
print nrfjprog.dll_version()
# It never exits this while() - just prints 'waiting' continuously
while (not nrfjprog.rtt_is_control_block_found()):
  print 'waiting for control block'
  time.sleep(1)
# This fails with JLINKARM_DLL_ERROR if we let it get here
nrfjprog.rtt_read(0,10000, encoding=None)
  • Yes, I was trying to run the PPK board mounted on a BMD-300 DK, not the Nordic DK. I switched to running the PPK board standalone as described in Section 5.6 in the User Guide and that worked. And I just received the correct Nordic DK board, and the DK+PPK solution works as well. Thanks!
  • Good to hear :)
