Receiving internal error on securing BLE link
At the moment I am working on a project that uses the nRF52328 acting as both a peripheral and central to connect 3 separate devices intermittently. I am storing their bonding information. A current problem I have now is that, due to an inconvenience with one of the devices, I have to create a new peer upon every connection. However, I noticed that whenever the number of peers exceeds PM_PEER_ID_N_AVAILABLE_IDS (from peer_manager_types.h) I receive NRF_ERROR_INTERNAL error code when I try to secure a link for the next device.
I tried deleting the old peer ids to make space but that doesn't seem to reduce the number of valid peers returned by pm_n_peers(). Running garbage collection when the memory is full also doesn't seem to resolve this. Is there anyway to solve this issue?
Edit: I notice that when the nrf52328 is reset /powered off and then on, pm_n_peers() returns the expected number of peers. i.e not including the deleted peers.
  • Ok. That explains it :) I recommend using a production version of the SDK, not an alpha, if that is inconvenient I recommend porting a newer version of the Peer Manager/FDS/Fstorage, to see if that fixes the issue. If I remember correctly, the Peer Manager library in SDK 10.0.0 (and SDK 11.0.0.2-alpha) was experimental, so quite a lot of changes and bug fixes have been applied in later releases.
  • Hi Peter, I have switched to SDK 11.0.0.0 and that seems to have corrected the issue. Thanks for the advice!
