hi all,
I have this problem:
After enable the indication i send for indication , with a snuffer ble i recieve them. But the master control panel lost the first?
Why?
Thanks, Anna
hi all,
Why?
Thanks, Anna
Could you upload the complete sniffer trace?
Hi Petter, i have the same problem with notify. I attached the two trace ( sniffer with developer studio) and nrftool. As you can see, the first is lost
Developer studio: the last 300 notification send ( you can see that the first is lost). Notify_Test1.cfa
NrfTool Log_2017-06-27_15_01_29[1].txt
Is Log_2017-06-27_15_01_29[1].txt and Notify_Test1.cfa from the same test? (the timestamp does not match.) Anyways, I see that you maybe are missing the notification with value 0B-00 ?
In the log, you have a test (at 10:54:18.102) where you get the 0B-00, but at 14:45:20.451, you are not getting this notification ? Did you do anything different between these 2 tests?
Hi siguard, yes is the same code. I have data write in eeprom and when enable indication i start to send to the APP.
The two txt are, one for the nrfTool and one for the Ble developer studio.
