Hi.I have a qusetion!Thanks!
After the host calls "sd_ble_gap_connect_cancel", the slave is not disconnected.
What causes this phenomenon?
Hi Shuhe,
You are probably using wrong SD GAP function. If there is connection already established you can terminate it by calling sd_ble_gap_disconnect. Note that it still doesn't guarantee that the opposite side of the link will react as you expect (e.g. if it has bug and doesn't understand LL_TERMINATE packet then it can assume that connection is ongoing, just packets are getting lost;).
Cheers Jan
