nRF51822 timer problems
Hi, I've been trying to use the timers on nRF51822 but I just can't get them to work in my code. When debugging (with GDB and Eclipse), the execution always stops with the following error: No source available for ""
timer_test [GDB Hardware Debugging] GDB Hardware Debugger (31.07.13 12:41) (Suspended) Thread [1] (Suspended: Signal 'SIGTRAP' received. Description: Trace/breakpoint trap.) 10 0xfffffffe 9 () 0xfffffff1 8 0x00011488 7 () 0xfffffff9 6 NVIC_SetPendingIRQ() core_cm0.h:558 0x00014810 5 timer_list_handler_sched() app_timer.c:324 0x00014ec6 4 timer_start_op_schedule() app_timer.c:786 0x00015610 3 app_timer_start() app_timer.c:1026 0x000159e0 2 timers_start() main.c:86 0x00014690 1 main() main.c:124 0x0001477c arm-none-eabi-gdb (31.07.13 12:41) C:\workspace\Nordic Semiconductor\nRF51 SDK_v4.3.0.27417\Nordic\nrf51822\Board\pca10001\ble\timer_test\gcc_build\timer_test_bin_s110_xxaa.out (31.07.13 12:41)
It seems to happen right when the function app_timer_start is called. It doesn't happen in any of the examples which use timers, but anytime I try to use them i get this error, so I must be doing something wrong but I have no idea what. Attached is a small project, which I modified from ble_app_template example, where I tried to get the timers working - maybe somebody can look at it and tell me what's wrong.
timer_test.zip
  • Hi Viktor,
    I had a look at your project. You are not enabling the S110 stack, which means that you will have to start your LFCLK manually. I also took the liberty of changing a couple of other things in your project, like the power_manage function and disabling the scheduler.
    Note: You are enabling the scheduler, but not using it.
    Best regards Håkon
    main.c
  • I've located my problem. app_timer is calling app_sched_event_put on a timeout. But when enter CRITICAL_REGION_ENTER() the device does not return from current_int_priority_get().
