Advertise on one channel at a time - app_timer problem
Hi DevZone
I want to make a little beacon app, that advertises on channel 37 then waits 700 ms, advertises on channel 38, waits 700 and advertises on channel 39. The below is what i have implemented, yet it doesn't work. It seems like the timeout handler is never called and therefor it is never starting advertising.
static void timers_init(void)
	uint32_t err_code;
	APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
	err_code = app_timer_create(&channel_timer_id, APP_TIMER_MODE_REPEATED, channel_timeout_handler);
My timeout handler which switches the channel_mode
static void channel_timeout_handler(void *p_context)
	SEGGER_RTT_printf(0, "Channel timeout handler %d\n, channel_mode");
	if(m_channel_mode == 37)
		m_channel_mode = 38;
	else if(m_channel_mode == 38)
		m_channel_mode = 39;
	else if(m_channel_mode == 39)
		m_channel_mode = 37;
	advertising_stop();
	advertising_init(m_channel_mode);
	advertising_start();
And here is my advertising_init where i set what channel it advertises on
static void advertising_init(uint8_t channel_mode)
		SEGGER_RTT_printf(0, "Advertising init\n");
    uint32_t      err_code;
    ble_advdata_t advdata;
		ble_gap_adv_ch_mask_t ch_mask; // channel mask
	  uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
		ble_uuid_t adv_uuids[] =
				{BLE_CUSTOM_16UUID, 		BLE_UUID_TYPE_BLE}
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
		advdata.include_appearance		= false;
		advdata.flags 								= flags;
    err_code = ble_advdata_set(&advdata, NULL);
		// Prepare the Manufacturer specific data packet
		ble_gap_addr_t gap_addr;
		sd_ble_gap_address_get(&gap_addr);
		ble_advdata_manuf_data_t manuf_data;
		manuf_data.company_identifier           = 0x028C; // 0x028C; // NanoLink Aps company ID
		//www.bluetooth.org/.../company-identifiers
		manuf_data.data.p_data									= gap_addr.addr;
		manuf_data.data.size                    = sizeof(gap_addr.addr);
    advdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    advdata.uuids_complete.p_uuids  = adv_uuids;
		advdata.p_manuf_specific_data   = &manuf_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
		m_adv_params.type					= BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
		m_adv_params.p_peer_addr	= NULL;
		m_adv_params.fp					  = BLE_GAP_ADV_FP_ANY;
		m_adv_params.interval			= NON_CONNECTABLE_ADV_INTERVAL;
		m_adv_params.timeout			= 0;
		m_adv_params.p_whitelist	= NULL;
		SEGGER_RTT_printf(0, "channel mode %d\n", channel_mode);
		if(channel_mode == 37)
			ch_mask.ch_37_off				 = 0;
			ch_mask.ch_38_off				 = 1;
			ch_mask.ch_39_off 			 = 1;
			m_adv_params.channel_mask = ch_mask;
		else if(channel_mode == 38)
			ch_mask.ch_37_off				 = 1;
			ch_mask.ch_38_off				 = 0;
		else if(channel_mode == 39)
And my main looks like this:
    uint32_t err_code;
    // Initialize.
//  APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false); // Comment this when channel switching on
		timers_init(); // init timers
		//gap_params_init();
    err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
    ble_stack_init();
		//advertising_init(m_channel_mode); //
		err_code = app_timer_start(channel_timer_id, CHANNEL_TIMER_INTERVAL, NULL);
	// Enter main loop.
    for (;; )
        power_manage();
  • Hello Mathias,
    Have you tried "ble_radio_notification" module? That might solve your problem without need to use timers, just alter data and channel through standard SD function calls after every adv. event so it's ready to use different channel (and data) on the very next event and keep time and other management to SoftDevice.
    Cheers Jan
    Edit 9-March-2017
    I've forgotten that there is no SD API function to just alter adv. channel map, this works only for adv./scan rsp. data and device (advertising) address. So the only way how to do it today is to stop/start advertising and that's not possible on radio notification event (to be precise it is but will destroy adv. interval timing). Would be great if Nordic adds such function to SD API in next Soft Device release but hard to say if such feature would be very useful. For the time being either application timer or hacking Soft Device RAM structures (and writing into them directly on radio notification event) is the way forward.
    Cheers Jan
  • Hi Jan, no worries! I learned quite a bit about how the softdevice works, which will be useful :-)
    I will try and write to the support and propose them to implement that feature in a newer version of the softDevice. In the meantime i think i will go back to application timer and try to implement it that way.
    If you succeed to write the channel map directly in the RAM structure, please give me a heads up :-)
    Mathias
    Mathias
