What are nRF52 advertisements exactly good for and what UUID do I have to put?
Hi!
So I managed to create my custom service with one characteristic (a struct with several attribs). I can see it in my app and everything's awesome. Yay.
But in some tutorial and in the sample app I altered initially (ble_bas sample), there is this struct:
static ble_uuid_t m_adv_uuids[] = {
    {BLE_UUID_POWER_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN},
    {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
}; /**< Universally unique service identifiers. */
As you can see I already put my own services UUID at the top. I also made it of type VENDOR_BEGIN as stated in the tutorial.
But it then fails to initiate the advertising. Additional data:
#define APP_UUID                         {{ 0xC0, 0xBE, 0xBA, 0xEE, 0xFF, 0xC0,0xBE, 0xBA, 0xEE, 0xFF, 0xC0,0xBE, 0xBA, 0xEE, 0xFF, 0xC0 }}
#define BLE_UUID_POWER_SERVICE 0xBABE
#define BLE_UUID_POWER_CHAR 0xB0BA
And I register my vendor UUID like this:
ble_uuid128_t   base_uuid = APP_UUID;
// Add vendor UUID
err_code = sd_ble_u
uid_vs_add(&base_uuid, &ble_uuid.type);
And as expected I register the characteristic and the service with BLE_UUID_POWER_SERVICE and BLE_UUID_POWER_CHAR respectively. This works fine!
So now my question is: If I can see my service already, what do I need the adverts for and how do I register them properly if needbe?
Thanks a lot!
    The point of advertising the UUID of available services, is to inform central devices of what services the device can provide, without the central needing to establish a connection to the device and perform a service discovery.
    If you place a central device in a room with 100 peripheral devices, where only one of the peripherals contain your power service, the central will not know which device to connect if you do not advertise the service UUID. Worst-case scenario, the central will have to connect to 100 peripherals, one by one, and perform a service discovery to know which one contains the correct service. If the service UUID is put in the advertising packet, the central can easily check if the service is available without establising a connection to any of the 100 peripherals.
    This saves time for the central device, and you avoid bothering the 99 peripheral devices that cannot offer the desired service.
    Note that the advertising packet is limited to 31 bytes. A vendor specific UUID is 128 bits (16 bytes), limiting the available space for name, other UUIDs, etc. You can also put the UUID in the scan response packet. This is described in chapter 5 of the BLE Advertising tutorial, and is also shown in the BLE UART example in the SDK.
    Jørgen
  • All advertised UUIDs will be in the same field, meaning you will not save any space on headers. This means that you have totally saved 14 bytes, less than the 16 bytes you added. If the advertising packet was already full, you might not have saved enough space. Please have a look at this comment about how the stack is able to advertise the full 128-bit UUID.
