command line gdb debugging symbols/stack trace
Using the pure-gcc makefiles, at present I only see this for a stack trace in the command line gdb client:
(gdb) bt
#0  0xfffffffe in ?? ()
#1  <signal handler called>
#2  0x00000000 in ?? ()
This is weird because I do have symbols:
(gdb) info break
Num     Type           Disp Enb Address    What
1       breakpoint     keep y   0x00017512 in main at ../main.c:100
2       breakpoint     keep y   0x00016c92 in gsm_uart_connect at ../gsm_ublox_sara.c:239
I'm using -ggdb in my CLFAGS:
CFLAGS += -DDEBUG -ggdb -O0
but have also tried with -g3:
CFLAGS += -DDEBUG -g3 -O0
I start the gdb server with:
JLinkGDBServer -if swd -device nrf51822 -speed 1000 -port 2331
and the client with:
/Users/Eliot/dev/gcc-arm-none-eabi-4_8-2013q4/bin/arm-none-eabi-gdb _build/device-nordic_s110.elf
My .gdbinit is just the one generated by the makefiles:
target remote localhost:2331
break main
(As an aside, it would be helpful to have a value for TERMINAL in the Makefiles for Mac so that I can simply run 'make startdebug', but I haven't been able to find one that works.)
  • The pure-gcc makefiles by default doesn't currently automatically load the binary and reset the chip, and if the flash contents isn't according to what GDB expects, you'll often see this 0xFFFFFFFE address.
    If you always want to do such load before you start debug, you can add the command load and mon reset to the gdbinit like this:
    load
    mon reset
    break main
    I'll consider changing this upstream as well, but the default behavior is useful if you want to connect to a running target... Thinking about it a second time however, the suggestion above is perhaps what's best for the 90 % use case, so it might make sense to change it.
  • Try:
    mon reset
    load
    mon reset
    continue
    The macro I use:
    define rc
       # reset and halt CPU
       mon reset
       printf "Run...\n"
       continue
    end
    define lc
       load
       rc
    end
    For me 'lc' prints:
    Loading section .text, size 0x151f8 lma 0x18000
    Loading section .ARM.exidx, size 0x8 lma 0x2d1f8
    Loading section .data, size 0xd8 lma 0x2d200
    Loading section .fill, size 0xbd24 lma 0x2d2d8
    Loading section .appCRC, size 0x4 lma 0x38ffc
    Start address 0x6d0, load size 135168
    Transfer rate: 13200 KB/sec, 3653 bytes/write.
    Resetting target
    Run...
    I used to use 'load' then 'run', but that requires 'gdb extended-remote' mode and some point in the recent past Segger broke breakpoint support in 'extended-remote' mode.
    I really don't trust the Segger stuff, I recently discovered if you load code onto a chip with the memory protection bits set, JLinkGDBServer will happily report:
    Downloading 4096 bytes @ address 0x00018000 - Verified OK
  • Try:
    mon reset
    load
    mon reset
    continue
    The macro I use:
    define rc
       mon reset
       printf "Run...\n"
       continue
    end
    define lc
       load
       rc
    end
    For me 'lc' prints:
    Resetting target
    Run...
