Using the pure-gcc makefiles, at present I only see this for a stack trace in the command line gdb client:
(gdb) bt
#0 0xfffffffe in ?? ()
#1 <signal handler called>
#2 0x00000000 in ?? ()
This is weird because I do have symbols:
(gdb) info break
Num Type Disp Enb Address What
1 breakpoint keep y 0x00017512 in main at ../main.c:100
2 breakpoint keep y 0x00016c92 in gsm_uart_connect at ../gsm_ublox_sara.c:239
I'm using -ggdb in my CLFAGS:
CFLAGS += -DDEBUG -ggdb -O0
but have also tried with -g3:
CFLAGS += -DDEBUG -g3 -O0
I start the gdb server with:
JLinkGDBServer -if swd -device nrf51822 -speed 1000 -port 2331
and the client with:
/Users/Eliot/dev/gcc-arm-none-eabi-4_8-2013q4/bin/arm-none-eabi-gdb _build/device-nordic_s110.elf
My .gdbinit is just the one generated by the makefiles:
target remote localhost:2331
break main
(As an aside, it would be helpful to have a value for TERMINAL in the Makefiles for Mac so that I can simply run 'make startdebug', but I haven't been able to find one that works.)
