pwm_driver period is always 50Hz.WHY?
Hello all,
I have created a BLE application on nRF52 PCA10040 devboard with S132 SD, in which I would like to use a PWM with the PWM_Driver. My pwm source code as below wants to control an RGB LED on GPIO outputs:
#define TOPVALUE 1000	/* Value up to which the pulse generator counter counts */
static nrf_drv_pwm_t pwm 	= NRF_DRV_PWM_INSTANCE(1);
static nrf_pwm_values_individual_t seq_values_pwm;		/* Duty cycle values */
static nrf_pwm_sequence_t const seq_pwm =				/* Sequence of duty cycle values */
	.values.p_individual = &seq_values_pwm,
	.length				 = NRF_PWM_VALUES_LENGTH(seq_values_pwm),
	.repeats			 = 0,
	.end_delay			 = 0
void PWM_Init_f(void){
   ret_code_t err_code;
   nrf_drv_pwm_config_t const config_pwm =
	   .output_pins =
		GPIO_O_PWM_RGB_R | NRF_DRV_PWM_PIN_INVERTED,			/* Channel 0 - RED   */
		GPIO_O_PWM_RGB_G | NRF_DRV_PWM_PIN_INVERTED,			/* Channel 1 - GREEN */
		GPIO_O_PWM_RGB_B | NRF_DRV_PWM_PIN_INVERTED, 			/* Channel 2 - BLUE  */
		GPIO_O_PWM_W     | NRF_DRV_PWM_PIN_INVERTED				/* Channel 3 - WHITE */
	   .irq_priority = APP_IRQ_PRIORITY_LOW,
       .base_clock   = NRF_PWM_CLK_1MHz,		/* Base Clock */
       .count_mode   = NRF_PWM_MODE_UP,
       .top_value    = TOPVALUE,
       .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
       .step_mode    = NRF_PWM_STEP_AUTO
   err_code = nrf_drv_pwm_init(&pwm, &config_pwm, NULL);
void PWM_Update_f(int16_t dutyR, int16_t dutyG, int16_t dutyB, int16_t dutyW)
   /* TOPVALUE - : because the LEDs are woring with negative logic */
   seq_values_pwm.channel_0 = TOPVALUE - dutyR;
   seq_values_pwm.channel_1 = TOPVALUE - dutyG;
   seq_values_pwm.channel_2 = TOPVALUE - dutyB;
   seq_values_pwm.channel_3 = TOPVALUE - dutyW;
   nrf_drv_pwm_simple_playback(&pwm, &seq_pwm, 1, NRF_DRV_PWM_FLAG_STOP);
And it is triggered in void main() while a button is pressed:
PWM_Init_f();
while (true)
	sd_app_evt_wait();
	if(nrf_gpio_pin_read(GPIO_I_BUTTON_4) == BUTTON_PRESSED)
		PWM_Update_f(100, 200, 500, 1000);
I detect the signals with an oscilloscope on GPIO output, and I always get 50 Hz (20 msec) periods between the edges. Do you know what I did wrong? I would like to have more than 120 Hz period between the edges because of dimming an RGB LED. How is it possible?
Thank you in advance!
Daniel
