sniffer missing packets
I have Wireshark version 1.10.14 and sniffer version 1.0.1. I send the data out from PCA10040 with connection interval of 7.5 ms and packet throughput of 200Hz using NUS service. I noticed that there are some packets that Wireshark do not show but I still have them received on Master point, which is an android app.
Is it normal for Sniffer to miss the packets? Is there any solution?
Vala
Edit: I added an image of Wireshark's output where this issue happens. I am sending 20 bytes packets in which the last two bytes (as a 16 bit integer) are increment in each iteration. UART packet numbers show the packet losses. Also I am sure that the Master has received the two missing packets here, which are the ones with the two last bytes of 0x530b and 0x530e.
image description
Edit: I added a PCAP file from Wireshark. The SDK that I did this test with is v11.0.0. And the peer device is an Acer tablet running a modified version of Nordic's UART app. The only modifications to the app were some changes in presenting the data.
Sniffer Packet Loss.pcap
