How to get my NRF_LOG, from macOS or iOS App or Win WM (DEV KIT NRF52)
Hello team,
I got a DEV KIT NRF52 And I'd like to get all my LOG : NRF_LOG_* ( NRF_LOG_INFO… ) From my USB interface Serial:
/dev/tty.usbmodem1421
I made sure that I activated sdk_config.h :
  • NRF_LOG_ENABLED 1
  • NRF_LOG_BACKEND_SERIAL_USES_RTT 1
  • NRF_LOG_BACKEND_SERIAL_USES_UART 1
I try a simple:
NRF_LOG_INFO("HELLO WORLD !\r\n");
In my function, which I invoke
I connect to tty via:
screen /dev/tty.usbmodem1421
Here's what I get some strange characters:
/2éé&2…
NOT my “HELLO WORLD” or whatever
I probably do not use the right method or the right program, If you could enlighten me to do it most ideally,
Thank you for your support
    Why do you enable both NRF_LOG_BACKEND_SERIAL_USES_RTT and NRF_LOG_BACKEND_SERIAL_USES_UART ?
    You should enable NRF_LOG_BACKEND_SERIAL_USES_UART only.
    Make sure you have included the nrf_log_backend_serial.c in your project.
    Which baudrate have you set for your UART? I assume you configured the correct pins matched with what on your board.
  • Hi Hung Bui,
    Thank you, indeed I had not thought about the conflict of USES_RTT and USES_UART
    With USES_UART only and by adding nrf_log_backend_serial.c in my project and let UART_BAUDRATE to 30801920 (115200 baud) and let pins matching at it was (UART_TX_PIN 6, UART_RX_PIN 8, UART_RTS_PIN 5, UART_CTS_PIN 7) I get all the logs of my app running on my NRF52!
    Thank you for your quick support
