Bootloader nRF52
Hi all,
I am trying to "add" the DFU bootloader to my application and I have some questions regarding it:
my thought are:
  1. add to DFU bootloader example code, part of my code adding the BLE capitability
-my code will run normally until the button is pressed to jump to the bootloader and perform the DFU
  1. add the DFU service to my current project and add the device manager, and more required libraries.
which option is most viable?
Update 03/06/17:
Softdevice $132
SDK 12.2
How can I swith from my aplication to the bootloader?
Thanks
  • Hi Arepa,
    I don't think option 1 would be a very good one. With this option, you have to do "bootloader update" whenever you want to update your firmware. Application update option has no use. When you do bootloader update, you are limited to the size of the bootloader which is written in UICR and can't be changed.
    Option 2 is much better one.
    You should consider Option 1 only when you want to do background DFU, where you device functional normally when you are receiving DFU. But this requires lots of change in the bootloader and on how to integrate it with your application.
  • Hi Arepa,
    Yes you can do that also. This requires you to modify the bootloader. The reason I suggested you to follow what we did in SDK v12 is for the compatibility with the future bootloader. But if you are OK with modifying the bootloader, then what you do is totally fine.
