pstorage callback never called
I'm running on nRF51822, SDK 8 (not totally sure, I inherited the project), SD130 and mbed.
I've tried and failed with my own code to use pstorage.
I'm now trying a modified version of the code found here for SDK 8.1: devzone.nordicsemi.com/.../
Long story short, the callback just never gets called.
Here's my main():
BLE   ble;
void main() {
      ble.init();
      while (!ble.hasInitialized()) { wait(0.01f); }
      pstorage_test_light();
      printf("Test");
Here's the test code:
static void power_manage(void)
  uint32_t err_code = sd_app_evt_wait();
static void example_cb_handler(pstorage_handle_t  * handle,
                               uint8_t              op_code,
                               uint32_t             result,
                               uint8_t            * p_data,
                               uint32_t             data_len)
  if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; }  //If we are waiting for this callback, clear the wait flag.
  switch(op_code)
    case PSTORAGE_LOAD_OP_CODE:
      if (result == NRF_SUCCESS)
        printf("pstorage LOAD callback received \r\n");
        //bsp_indication_set(BSP_INDICATE_ALERT_0);
        printf("pstorage LOAD ERROR callback received \r\n");
        //bsp_indication_set(BSP_INDICATE_RCV_ERROR);
    case PSTORAGE_STORE_OP_CODE:
        printf("pstorage STORE callback received \r\n");
        //bsp_indication_set(BSP_INDICATE_ALERT_1);
        printf("pstorage STORE ERROR callback received \r\n");
    case PSTORAGE_UPDATE_OP_CODE:
        printf("pstorage UPDATE callback received \r\n");
        //bsp_indication_set(BSP_INDICATE_ALERT_2);
        printf("pstorage UPDATE ERROR callback received \r\n");
    case PSTORAGE_CLEAR_OP_CODE:
        printf("pstorage CLEAR callback received \r\n");
        //bsp_indication_set(BSP_INDICATE_ALERT_3);
        printf("pstorage CLEAR ERROR callback received \r\n");
void pstorage_test_light(void)
  pstorage_handle_t       handle;
  pstorage_handle_t				block_0_handle;
  pstorage_module_param_t param;
  uint8_t                 source_data_1[16] = {0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F};
  uint32_t                retval;
  retval = pstorage_init();
  if(retval != NRF_SUCCESS)
    //bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
  param.block_size  = 16;                   //Select block size of 16 bytes
  param.block_count = 4;                   //Select 10 blocks, total of 160 bytes
  param.cb          = example_cb_handler;   //Set the pstorage callback handler
  printf("\r\n\r\npstorage initializing ... \r\n");
  retval = pstorage_register(&param, &handle);
  if (retval != NRF_SUCCESS)
//		//Get block identifiers
  pstorage_block_identifier_get(&handle, 0, &block_0_handle);
  printf("pstorage store into block 1 \r\n");
  pstorage_store(&block_0_handle, source_data_1, 16, 0);     //Write to flash, only one block is allowed for each pstorage_store command
  pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
  pstorage_wait_flag = 1;                                    //Set the wait flag. Cleared in the example_cb_handler
  while(pstorage_wait_flag) { power_manage(); }              //Sleep until store operation is finished.
And I can put a breakpoint in btle.cpp:
static void sys_evt_dispatch(uint32_t sys_evt)
  pstorage_sys_event_handler(sys_evt);
It never gets hit. power_manage() is called continuously and the app loops.
I must be missing something, but can't figure what! Any help appreciated!
Edit: Petter pointed something I forgot to say: all the possible conditions of error have been checked, pstorage_register, pstorage_block_identifier_get and pstorage_store have been checked separatly (a breakpoint on each error condition), breakpoints never got hit.
