fds_record_find error code = FDS_ERR_NOT_INITIALIZED
I am trying to read and write data from flahs using the fds library. For the moment my main problem is that when calling fds_record_find, it returns FDS_ERR_NOT_INITIALIZED (0x02). I tried to understand why, and I found that m_flags is set to 0x05 (FDS_FLAG_INITIALIZING | FDS_FLAG_PROCESSING) after the end of fds_init(). fds_record_find is checking if m_flags is set to FDS_FLAG_INITIALIZED (0x02), which returns this error. fds_init returns FDS_SUCCESS.
I am using SDK v11.0.0 and softdevice s130 v2.0.0. My target is an nRF51822 QFACA1
Here is my code concerning the fds module. flash_init is called after all the ble init functions excepted advertising_start :
static void fds_evt_handler(fds_evt_t  const * const p_evt){
    switch (p_evt->id)
        case FDS_EVT_INIT:
            if (p_evt->result != FDS_SUCCESS)
                // Initialization failed.
				case FDS_EVT_WRITE:
						if (p_evt->result == FDS_SUCCESS)
							write_flag=1;
/**@brief Function to read the data from the flash on initialization
void flash_init(){
#ifdef TEST_FLASH
	static fds_find_token_t test_token = {0};
	static fds_flash_record_t test_record;
	uint32_t ret_code = fds_register(fds_evt_handler);
	if (ret_code == FDS_ERR_USER_LIMIT_REACHED)
    	SEGGER_RTT_WriteString(0, "fds_register : FDS_ERR_USER_LIMIT_REACHED.\n");
	else if (ret_code == FDS_SUCCESS)
		SEGGER_RTT_WriteString(0, "fds_register : FDS_SUCCESS.\n");
		SEGGER_RTT_printf(0, "fds_register unknown error code : 0x%x.\n", ret_code);
	ret_code = fds_init();
	if (ret_code == FDS_ERR_NO_PAGES)
		SEGGER_RTT_WriteString(0, "fds_init : FDS_ERR_NO_PAGES.\n");
		SEGGER_RTT_WriteString(0, "fds_init : FDS_SUCCESS.\n");
		SEGGER_RTT_printf(0, "fds_init unknown error code : 0x%x.\n", ret_code);
	nrf_delay_ms(1000);
	uint32_t record_find = fds_record_find(test_file_id, test_record_key, &test_descriptor, &test_token);
	SEGGER_RTT_printf(0, "fds_record_find error code : 0x%x.\n", record_find);
	while(record_find==FDS_SUCCESS){
		ret_code = fds_record_open(&test_descriptor, &test_record);
		if (ret_code == FDS_ERR_NULL_ARG)
			SEGGER_RTT_WriteString(0, "fds_record_open : FDS_ERR_NULL_ARG.\n");
			SEGGER_RTT_WriteString(0, "fds_record_open : FDS_SUCCESS.\n");
		else if (ret_code == FDS_ERR_NOT_FOUND)
			SEGGER_RTT_WriteString(0, "fds_record_open : FDS_ERR_NOT_FOUND.\n");
			SEGGER_RTT_printf(0, "fds_record_open unknown error code : %d.\n", ret_code);
		memcpy(&test, test_record.p_data, 4);
		ret_code = fds_record_close(&test_descriptor);
			SEGGER_RTT_WriteString(0, "fds_record_close : FDS_ERR_NULL_ARG.\n");
			SEGGER_RTT_WriteString(0, "fds_record_close : FDS_SUCCESS.\n");
			SEGGER_RTT_WriteString(0, "fds_record_close : FDS_ERR_NOT_FOUND.\n");
		else if (ret_code == FDS_ERR_NO_OPEN_RECORDS)
			SEGGER_RTT_WriteString(0, "fds_record_close : FDS_ERR_NO_OPEN_RECORDS.\n");
			SEGGER_RTT_printf(0, "fds_record_close unknown error code : %d.\n", ret_code);
		if (record_find != FDS_SUCCESS)
	SEGGER_RTT_printf(0, "test 0x%#08x.\n", test);
    SEGGER_RTT_WriteString(0, "Flash init terminated.\n");
static ret_code_t fds_test_find_and_delete (void)
		fds_record_desc_t   record_desc;
		fds_find_token_t    ftok;
		ftok.page=0;
		ftok.p_addr=NULL;
		// Loop and find records with same ID and rec key and mark them as deleted.
		while (fds_record_find(test_file_id, test_record_key, &record_desc, &ftok) == FDS_SUCCESS)
			fds_record_delete(&record_desc);
			SEGGER_RTT_printf(0,"Deleted record ID: %d \r\n",record_desc.record_id);
// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
		ret_code_t ret = fds_gc();
		if (ret != FDS_SUCCESS)
				return ret;
		return NRF_SUCCESS;
void power_off(void){
	test = 0x12345678;
	static fds_record_chunk_t test_chunk;
	fds_record_t test_record;
	nrf_drv_gpiote_in_event_disable(RTC_NIRQ);
	//Turn ON the LED display for power off
	twi_enable();
	displayOnOff();
	nrf_delay_ms(2000);
	displayOff();
    /*if(nOFFindex<5){
    	nOFF[nOFFindex]=n;
    	nOFFindex++;
	n++;
	test_record.file_id = test_file_id;
	test_record.key = test_record_key;
	test_chunk.p_data = &test;
	test_chunk.length_words = 1;
	test_record.data.p_chunks = &test_chunk;
	test_record.data.num_chunks = 1;
	SEGGER_RTT_WriteString(0,"Flash writing begins : fds_test_find_and_delete(). \n");
	uint32_t err_code = fds_test_find_and_delete();
	if (err_code != FDS_SUCCESS)
		SEGGER_RTT_printf(0, "fds_test_find_and_delete err_code : 0x%x. \n", err_code);
	//uint32_t err_code = fds_record_update(&test_descriptor, &test_record);
	SEGGER_RTT_WriteString(0,"fds_record_write. \n");
	err_code = fds_record_write(&test_descriptor, &test_record);
	if (err_code == FDS_SUCCESS)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_SUCCESS. \n");
	else if (err_code == FDS_ERR_NOT_INITIALIZED)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_NOT_INITIALIZED. \n");
	else if (err_code == FDS_ERR_INVALID_ARG)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_INVALID_ARG. \n");
	else if (err_code == FDS_ERR_UNALIGNED_ADDR)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_UNALIGNED_ADDR. \n");
	else if (err_code == FDS_ERR_RECORD_TOO_LARGE)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_RECORD_TOO_LARGE. \n");
	else if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_NO_SPACE_IN_QUEUES. \n");
	else if (err_code == FDS_ERR_NO_SPACE_IN_FLASH)
		SEGGER_RTT_WriteString(0, "fds_record_update : FDS_ERR_NO_SPACE_IN_FLASH. \n");
		SEGGER_RTT_printf(0, "fds_record_update unknown error code : 0x%x. \n", err_code);
	SEGGER_RTT_WriteString(0,"wait until writing is finished. \n");
	while (write_flag==0); //Wait until writing is finished
	//APP_ERROR_CHECK(err_code);
	SEGGER_RTT_WriteString(0,"Shutdown \n");
	nrf_gpio_pin_clear(EN);
Guillaume
