While building the beacon example in segger studio, it shows the error: invalid storage class for functions 'is diabled in debug needed', ' is_manual_peripheral_setup_needed', 'is_peripheral_domain_setup_needed in system_nrf51.c. How to
/* Copyright (c) 2012 ARM LIMITED
  • All rights reserved.
  • Redistribution and use in source and binary forms, with or without
  • modification, are permitted provided that the following conditions are met:
    • Redistributions of source code must retain the above copyright notice, this
  • list of conditions and the following disclaimer.
    • Redistributions in binary form must reproduce the above copyright notice,
  • this list of conditions and the following disclaimer in the documentation
  • and/or other materials provided with the distribution.
    • Neither the name of ARM nor the names of its contributors may be used to
  • endorse or promote products derived from this software without specific
  • prior written permission.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  • AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  • IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  • DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  • FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  • DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  • SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  • CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  • OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  • OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* NOTE: Template files (including this one) are application specific and therefore expected to be copied into the application project folder prior to its use! */
#include <stdint.h> #include <stdbool.h> #include "nrf.h" #include "system_nrf51.h"
/*lint ++flb "Enter library region" */
#define __SYSTEM_CLOCK (16000000UL) /*!< nRF51 devices use a fixed System Clock Frequency of 16MHz */
static bool is_manual_peripheral_setup_needed(void); static bool is_disabled_in_debug_needed(void); static bool is_peripheral_domain_setup_needed(void);
#if defined ( __CC_ARM ) uint32_t SystemCoreClock attribute((used)) = __SYSTEM_CLOCK; #elif defined ( ICCARM ) __root uint32_t SystemCoreClock = __SYSTEM_CLOCK; #elif defined ( GNUC ) uint32_t SystemCoreClock attribute((used)) = __SYSTEM_CLOCK; #endif
void SystemCoreClockUpdate(void) { SystemCoreClock = __SYSTEM_CLOCK; }
void SystemInit(void) { /* If desired, switch off the unused RAM to lower consumption by the use of RAMON register. It can also be done in the application main() function. */
/* Prepare the peripherals for use as indicated by the PAN 26 "System: Manual setup is required
   to enable the use of peripherals" found at Product Anomaly document for your device found at
   https://www.nordicsemi.com/. The side effect of executing these instructions in the devices
   that do not need it is that the new peripherals in the second generation devices (LPCOMP for
   example) will not be available. */
if (is_manual_peripheral_setup_needed())
    *(uint32_t volatile *)0x40000504 = 0xC007FFDF;
    *(uint32_t volatile *)0x40006C18 = 0x00008000;
/* Disable PROTENSET registers under debug, as indicated by PAN 59 "MPU: Reset value of DISABLEINDEBUG
   register is incorrect" found at Product Anomaly document for your device found at
   https://www.nordicsemi.com/. There is no side effect of using these instruction if not needed. */
if (is_disabled_in_debug_needed())
    NRF_MPU->DISABLEINDEBUG = MPU_DISABLEINDEBUG_DISABLEINDEBUG_Disabled << MPU_DISABLEINDEBUG_DISABLEINDEBUG_Pos;
/* Execute the following code to eliminate excessive current in sleep mode with RAM retention in nRF51802 devices,
   as indicated by PAN 76 "System: Excessive current in sleep mode with retention" found at Product Anomaly document
   for your device found at https://www.nordicsemi.com/. */
if (is_peripheral_domain_setup_needed()){
    if (*(uint32_t volatile *)0x4006EC00 != 1){
        *(uint32_t volatile *)0x4006EC00 = 0x9375;
        while (*(uint32_t volatile *)0x4006EC00 != 1){
    *(uint32_t volatile *)0x4006EC14 = 0xC0;
static bool is_manual_peripheral_setup_needed(void) { if ((((*(uint32_t )0xF0000FE0) & 0x000000FF) == 0x1) && ((((uint32_t )0xF0000FE4) & 0x0000000F) == 0x0)) { if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0x00) && ((((uint32_t )0xF0000FEC) & 0x000000F0) == 0x0)) { return true; } if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0x10) && ((((uint32_t )0xF0000FEC) & 0x000000F0) == 0x0)) { return true; } if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0x30) && ((((uint32_t *)0xF0000FEC) & 0x000000F0) == 0x0)) { return true;
return false;
static bool is_disabled_in_debug_needed(void) { if ((((*(uint32_t )0xF0000FE0) & 0x000000FF) == 0x1) && ((((uint32_t )0xF0000FE4) & 0x0000000F) == 0x0)) { if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0x40) && ((((uint32_t *)0xF0000FEC) & 0x000000F0) == 0x0)) { return true; } }
return false;
static bool is_peripheral_domain_setup_needed(void) { if ((((*(uint32_t )0xF0000FE0) & 0x000000FF) == 0x1) && ((((uint32_t )0xF0000FE4) & 0x0000000F) == 0x0)) { if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0xA0) && ((((uint32_t )0xF0000FEC) & 0x000000F0) == 0x0)) { return true; } if (((((uint32_t )0xF0000FE8) & 0x000000F0) == 0xD0) && ((((uint32_t *)0xF0000FEC) & 0x000000F0) == 0x0)) { return true; } }
return false;
/*lint --flb "Leave library region" */
1 2
