Hello Nordic developers,
I have been unsuccessfully trying to use the extended ATT_MTU / DLE sizes for increased throughput on a nRF52832DK board running the Nordic UART Service, using SDK 12.2.0 and S132v3.1.0. I am trying to increase data throughput on a UART over BLE connection with an Android device.
Of course, I followed the mini-guide, as well as these relevant posts on the forum - post 1, post 2, and post 3.
To summarize, here are the changes that I have made to the ble_peripheral/ble_app_uart example code:
In main.c, changed FROM
TO#define NRF_BLE_MAX_MTU_SIZE GATT_MTU_SIZE_DEFAULT
#define NRF_BLE_MAX_MTU_SIZE 247
In ble_nus.h, ADDED
#define NRF_BLE_MAX_MTU_SIZE 247and changed FROM
TO#define BLE_NUS_MAX_DATA_LEN (GATT_MTU_SIZE_DEFAULT - 3)#define BLE_NUS_MAX_DATA_LEN (NRF_BLE_MAX_MTU_SIZE-3) -
In sdk_config.h, ADDED
#ifndef NRF_BLE_GATT_MAX_MTU_SIZE #define NRF_BLE_GATT_MAX_MTU_SIZE 247 #endiffrom ble_stack_handler_types.h
In ble_stack_init.c, enable the softdevice, set DLE size and enable event extension:
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize SoftDevice.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
#if (NRF_SD_BLE_API_VERSION == 3)
ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
err_code = softdevice_enable(&ble_enable_params);
// Subscribe for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
/// ---- DLE stuf ----
#if (NRF_SD_BLE_API_VERSION==3)
//set DLE size
ble_opt_t opt;
opt.gap_opt.ext_len.rxtx_max_pdu_payload_size = NRF_BLE_MAX_MTU_SIZE+4;
sd_ble_opt_set(BLE_GAP_OPT_EXT_LEN, &opt);
//enable event extension
opt.common_opt.conn_evt_ext.enable = 1;
sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
///end of DLE stuff
I realize that all of this code is the same as the sample posted by Petter Myhre in post 2.
With my current setup, I am requesting MTU extension from the Android device as the connection is started. With the basic NUS example, I can receive 20B of data per packet, and when requesting MTU extension, receive 23B as the max MTU size (as expected).
Now, here comes the tricky part. When I make the above mentioned changes to code, I don't think the softdevice is initializing. On debugging, the device runs in loop between main() -> uart_init() -> buttons_led_init(&erase_bonds) -> ble_stack_init() -> main() ->........ And so I cannot seem to get it to work!
I suspect that I have not properly adjust the RAM for the soft device (and unsure of how to properly do so), or am making a mistake in changing the DLE settings with the softdevice. NOTE: I was also not able to run the sample code from post #2 and noticed the same issue.
Perhaps there is some way of initializing the soft device with the default ATT_MTU settings, and then modify the softdevice settings dynamically post-connection?
Any suggestions with this would be great!
