nrf8001 DC/DC enabling and then Error
Im having errors like Arduino is in the while(1) loop if I enable the DC/DC converter in the characteristics and generate service.h file , If I do not use this setting everything is fine! How to tackle such a problem?
ERROR details:
Evt Connected
Evt Pipe Status
data transmmit success! Length: 20 Data Credit available: 1
ACI Evt Pipe Error: Pipe #:4 Pipe Error Code: 0x95
Data Credit available: 2
ACI Command D
Evt Cmd respone: Error. Arduino is in an while(1); loop
RBL_BLEShield.xml
  • I tried your XML as is and by enabling the DC-DC converter in the hardware settings and both seem to work. I used a nRF2740 board with the Arduino adapter shield as in the nRF8001 development kit.
    I would suggest that you send your schematic for review. In addition I also suggest that you do the lib_aci_set_local_data() on a SET pipe. I.e. add a SET pipe to the UART TX characteristic.
  • I have solved it by reverting to the standard library that was happening due to a bug in RedBearLabs library(their support Sucks! big time) now its working with DC/DC converter ON and I'm happy.
    Still I got one thing left now in my bucket to solve and its when to sleep the uC? I'm right now getting it to sleep WHEN THERE ARE NO ACI EVENTS I think I'm doing right, the uC sleeps but I'm not able to wake up despite the fact that RDYN is connceted to pin 2 and as I use ATmega328 its the lowest level hardware interrupt that should make the uC wake up but itis not happning ,I have the issue covered here >> http://forums.adafruit.com/viewtopic.php?f=19&t=52043
