RTC stops after disconnet from Android
Hi, I am using nrf51822 chip. I am using RTC to generate irq with CC. Everything works fine for IOS and old Android version. New android version makes 2 things when I disconnect:
  1. change register of CC[0] value so I changed to generate IRQ from CC[1]:
    void lfclk_config(void) { ret_code_t err_code = nrf_drv_clock_init(NULL); APP_ERROR_CHECK(err_code);
     nrf_drv_clock_lfclk_request();
     uint32_t err_code;
     //Initialize RTC instance
     err_code = nrf_drv_rtc_init(&rtc, NULL, rtc_handler);
     //Enable tick event & interrupt
     nrf_drv_rtc_tick_enable(&rtc,false);
     //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
     err_code = nrf_drv_rtc_cc_set(&rtc,1,P*60*8,true);
     //Power on RTC instance
     nrf_drv_rtc_enable(&rtc);
  2. stops RTC after disconnect.
I don't have any idea why on IOS works fine but on new Android it doesn't.
Thanks for help in advance.
  • Sorry but it doesn't make sense that any external BLE device by connecting influences state of nRF5x registers like this. It must be code running on nRF5x chip which causes it, e.g. Soft Device. What SD are you running? What RTC instance are you using, how you initialize it etc.?
  • I know it doesn't have any sense. I use soft device 110, I use RTC 1 to get irq. This is my initialization code. It's weird that at IOS or Android with old version everything works fine, but when I getting disconnet with new Android the register is changing and RTC stops. Main loop and other tasks works fine. It`s happens even when I am using NRF uart application.
    const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(1);
    void rtc_config(void)
        uint32_t err_code;
    	err_code = nrf_drv_rtc_cc_set(&rtc,1,2*60*8,true);
    BLE config here:
    uint32_t BLE_config(void)
    	uint32_t err_code;
    	APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    	ble_stack_init();
    	gap_params_init();
    	services_init();
    	advertising_init(APP_ADV_START_TIMEOUT_IN_SECONDS);
    	conn_params_init();
    	//err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    	//APP_ERROR_CHECK(err_code);
        return err_code;
        uint32_t err_code;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
        // Enable BLE stack.
        ble_enable_params_t ble_enable_params;
        memset(&ble_enable_params, 0, sizeof(ble_enable_params));
    #if (defined(S130) || defined(S132))
        ble_enable_params.gatts_enable_params.attr_tab_size   = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
        ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
        err_code = sd_ble_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    void advertising_init(uint16_t timeout)
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags=BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        advdata.uuids_complete.p_uuids  = m_adv_uuids;
        ble_adv_modes_config_t options = {0};
        options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = timeout;
        options.ble_adv_slow_enabled = BLE_ADV_SLOW_ENABLED;
        options.ble_adv_slow_interval = 2056;
        options.ble_adv_slow_timeout = timeout;
        err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
    I post the logs from terminal from 3 phones.
    rtc counter CC
    Android 4.3 Samsung gt-i9300 with CC[0]: image description
    Iphone 6S with system 10.2.1 with CC[0]: image description
    and now Android 7.0 Samsung s7 edge with CC[0]: image description
    Android 7.0 Samsung s7 edge with CC[1]: image description
    Here is my code, sorry for a mess but this is just a test code: BLE_NEW_mod.rar
    Now it`s working. Here is log:
    image description
    The problem was in using app_timer library.
    Thanks a lot for help!
  • Hi Marcin,
    Could you make sure you don't have any other code or other module that may use the RTC ?
    Which value the CC[0] changed to after you disconnect from the new Android phone ?
    Which Android version was that and which phone did you use ?
    Could you provide the nRF UART version with your modification that can reproduce the issue ?
