Eclipse GCC pure project for DFU Bootloader nRF51
I have created Eclipse project to compile nRF51 DFU loader. This is a pure Eclipse project, no makfile. It has compile configurations for combination of Single/Dual bank and BLE/Serial. This project require installed nRF51 SDK 5.2 in the same work space under with sdk directory name nrf51_sdk. The project has file links to the source in the sdk hence the sdk directory need to be that name. This will allow you to update to new sdk easier.
Here are the prerequisite.
Eclipse Keplar CDT Eclipse ARM plus ins: Follow this blog gnuarmeclipse.livius.net/.../. this contains support for jlink as well GCC compiler : launchpad.net/gcc-arm-embedded
Here are the attached files common.zip contains common folder to be place in same workspace. dfu_nrf51.zip is the project folder. It contains precompiled & tested hex release version of 4 binations if you don't want to recompile.
Workspace directory should have
Workspace | Common | dfu_nrf51 | nrf51_sdk
I hope this helps anyone who wants to work with Eclipse & GCC.
Good luck
Update sep. 18, 2014
Updated projects with sdk 6.1 on blog site here embeddedsoftdev.blogspot.ca/.../ehal-nrf51.html
  • in compiler_abstraction.h file, at line 73. replace asm("sp") with __asm("sp")
  • Got it, thanks!..
    Now, the build stops with
    Building file: /Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Source/app_common/pstorage.c
    Invoking: Cross ARM C Compiler
    arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g3 -DPSTORAGE_RAW_ACCESS -DNRF51 -DDEBUG_NRF_USER -DNRF51822_QFAA_GC -DBLE_STACK_SUPPORT_REQD -DBOARD_PCA10001 -I"/Volumes/UsersX9/rasit/Documents/workspace/dfu_nrf51/src/include" -I"/Volumes/UsersX9/rasit/Documents/workspace/dfu_nrf51/src/include/ble_transport" -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/sd_common -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/ble -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/s110 -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/ble/ble_services -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/app_common -I/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/gcc -std=c99 -MMD -MP -MF"src/nrf51_sdk/pstorage.d" -MT"src/nrf51_sdk/pstorage.o" -c -o "src/nrf51_sdk/pstorage.o" "/Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Source/app_common/pstorage.c"
    In file included from /Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Source/app_common/pstorage.c:13:0:
    /Volumes/UsersX9/rasit/Documents/workspace/nrf51_sdk/nrf51822/Include/app_common/pstorage.h:28:31: fatal error: pstorage_platform.h: No such file or directory
    compilation terminated.
    make: *** [src/nrf51_sdk/pstorage.o] Error 1
    I guess, it depends which soft devise I'm using, or no?
  • Thanks Nguyen, now it works.
    Invoking: Cross ARM GNU Print Size arm-none-eabi-size --format=berkeley "dfu_nrf51.elf" text data bss dec hex filename 13219 1036 2004 16259 3f83 dfu_nrf51.elf Finished building: dfu_nrf51.siz
  • Hi, I remember a similar issue, have you changed language standard from -std =C99 to -std=gnu99 ? You can do it in Settings.
    -c
  • Try first to change language standard using original pastorage.h
    -c
