Eclipse GCC pure project for DFU Bootloader nRF51
I have created Eclipse project to compile nRF51 DFU loader. This is a pure Eclipse project, no makfile. It has compile configurations for combination of Single/Dual bank and BLE/Serial. This project require installed nRF51 SDK 5.2 in the same work space under with sdk directory name nrf51_sdk. The project has file links to the source in the sdk hence the sdk directory need to be that name. This will allow you to update to new sdk easier.
Here are the prerequisite.
Eclipse Keplar CDT Eclipse ARM plus ins: Follow this blog gnuarmeclipse.livius.net/.../. this contains support for jlink as well GCC compiler : launchpad.net/gcc-arm-embedded
Here are the attached files common.zip contains common folder to be place in same workspace. dfu_nrf51.zip is the project folder. It contains precompiled & tested hex release version of 4 binations if you don't want to recompile.
Workspace directory should have
Workspace | Common | dfu_nrf51 | nrf51_sdk
I hope this helps anyone who wants to work with Eclipse & GCC.
Good luck
Update sep. 18, 2014
Updated projects with sdk 6.1 on blog site here embeddedsoftdev.blogspot.ca/.../ehal-nrf51.html
  • Yes, I did change it. It is set with the project settings. The SDK require C99 to compile. It is also my preferred settings.
  • You only need to set the include path to the location of pstorage_platform.h
  • C99 or gnu99 ?
    Hi Nguyen, there in a strange behavior in your code, infact, if i compile with -std=gnu99 all goes ok but if I set -std=C99 (your preferred choice and , as you said, needed by SDK to be compiled) these errors was raised :
    /nrf51_sdk/nrf51822/Include/compiler_abstraction.h:73:30: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'asm'
    /nrf51_sdk/nrf51822/Include/compiler_abstraction.h:73:30: warning: implicit declaration of function 'asm' [-Wimplicit-function-declaration]
    /nrf51822/Include/compiler_abstraction.h:74:16: error: 'sp' undeclared (first use in this function)
    More interesting is the fact you do not use the asm file gcc_startup_nrf51.S but a translation from asm to c file StartupnRF51.c .
    Can you tell me more about ? Is it possible to compile using using the original asm file or changes are needed ?
    Does this file be compatible with all SDK (old and news) or must be rewritten ad hoc for every SDK?
    If I would compile hrf example to be used with boot loader generated from you eclipse project I need to change specific address memory flashing with jlinkexe (os x version) or the firmware starts at the same address (0x014000) ?
    Thanks.
    -c
  • The compiler_abstraction.h is not my code. It's the SDK and there is an error in that file. Then inline assembly in GNU compile is __asm(...) not asm(...). You need to change it.
    The StartupnRF51.c is not a translation of the .s file. It was ported form my other ARM processor. I write multi-platform code. It does not depend on the SDK. It is generic for GNU compiler and ARM processors. Now a day writing code in assembly is only for special optimization. Otherwise not recommended. It is a maintenance nightmare.
    The dfu code is still all Nordic code. I only make few changes to make it compiles with GNU. mainly asm stuff. So yes App needs to start at 0x14000. No change to that.
  • I forgot your question about using the gcc_startup_nrf51.S. Yes you can use it. You will need to use the linker script from the SDK too. I made few changes in the linker script for my startup code.
