Change RAM size for SoftDevice
Hi. I'm using nRF51822AC, SDK12.2.0, S130 v2.0.1 as Multi-link central.
My project's RAM setting :
IRAM1 Start : 0x20005040, Size : 0x2FC0 following example code "ble_app_multilink_central". But RAM size for App(0x2FC0 = 12KB around) is too small.
As I know the RAM area 0x20000000~0x20005040 is for 8 connections Soft device.
Q1. Is it possible to reduce the RAM size for SoftDevice? If I reduce the number of connections. I think It makes App's RAM size bigger.
Q2. If possible, How can I set the App's RAM size for each case? for example)
7connections : IRAM1 Start : 0x20005000, Size : 0x3000
6connections : IRAM1 Start : 0x20004FC0, Size : 0x3040
5connections : IRAM1 Start : 0x20004F80, Size : 0x3080 ......
I need your help.
  • Hi Roger,
    Q1: Yes, it is possible to reduce the RAM requirement of the SoftDevice by reducing the number of concurrent connections.
    Q2: The sd_ble_enable function, which is used to enable the SoftDevice, will return the minimum start address of the application RAM region required by the SoftDevice for the given configuration in the app_ram_base variable. The value of app_ram_base will be printed on the UART/RTT if you have logging enabled. You can also open a debug session, set a breakpoint after the in softdevice_enable(ble_enable_params_t * p_ble_enable_params) function in softdevice_handler.c and examine the value of app_ram_base that way.
    Best regards
    Bjørn
  • yes. This is very cool. Can you please tell me how to enable logging? and how to take the logs?
