I am trying to get to the bottom of a double-reset-problem which I am facing, whenever I flash my software-program to the nRF52832 (1 for the flashing and 1 after a short startup).
Currently I am using a Windows 8.1 machine with an Eclipse Neon2-GCC-Toolchain and the latest J-Link V614a-Firmware.
Here are some log-outputs that might help describing the situation:
a) Eclipse Neon2 (after flashing)
nrfjprog --reset -f nrf52
Applying system reset.
Run.
09:43:45 Build Finished (took 3s.451ms)
First thought was that I might have accidently given a double-reset in the Makefile itself, but as you can see there is nothing spectacular here and everything just seems fine!
b) puTTY (after Startup)
0.000013 : UART Start!
0.000220 : Reset code [0x00040005 | 0x00000000]
0.344855 : BLE Stack Initialized
0.345083 : Peer Manager Initialized
0.345273 : MAC Address 00:AA:BB:CC:DD:EE
0.348501 : Services initialized
0.348753 : Advertising Initialized
0.349128 : Reset code [0x00040005 | 0x00000000]
0.249888 : BLE Stack Initialized
0.250117 : Peer Manager Initialized
0.250301 : MAC Address 00:AA:BB:CC:DD:EE
0.253504 : Services initialized
0.253762 : Advertising Initialized
0.254141 : Reset code [0x00040005 | 0x00000000]
This is the usual output (99% of the time) that I am getting on the UART right after flashing my software. I also tried to debug the reset codes from RESETREAS- and GPREGRET-registers but that still left me clueless. Isnt RESETREAS supposed to show normally just a 1 for each of the reset reasons specified in the nRF52832 Product Spec v1.0? In addition to that, is it correct that there can never be more then 1 reset reason?
0.507008 : BLE Stack Initialized
0.507762 : Peer Manager Initialized
0.508152 : SYS-EVENT-DISPATCH 2
268.943403 : MAC Address 00:AA:BB:CC:DD:EE
0.253794 : BLE Stack Initialized
0.254021 : Peer Manager Initialized
0.254205 : MAC Address 00:AA:BB:CC:DD:EE
0.257392 : Services initialized
0.257645 : Advertising Initialized
0.258029 : Reset code [0x00040005 | 0x00000000]
This was pretty much a 1%-time output, where the 1st output shows a SYS_EVENT-dispatch 2, that stands for the event NRF_EVT_FLASH_OPERATION_SUCCESS and therefore a successful software-flash. Still I am not getting why the reset occurs here!? (The timestamp-gap can be ignored, its a calculation problem!)
The only observation that I can contribute so far is, that the new J-Link V614a-Firmware might be the source of the problem, because the same hardware showed a normal reset after flashing on a different PC with just J-Link V512g which came originally with the Nordic SDK itself. Havent tried using the older firmware-driver on the PC with a newer on the Nordic DK though, because I didnt wanted to cause any mailfunction.
Any1 got an idea?
Thanks in advance!
