I have followed a couple of the posts on the devzone on how to increase the MTU and add the DLE support such as this.
However, whenever I send over 20 bytes of data I get an "app_error_fault".
I have logging enabled and changed my ram size so my ram should be set correctly.
I have set the MTU size in sdk_config.h:
#define NRF_BLE_MAX_MTU_SIZE 75 -
I set the att size in the setup function
ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE; -
I have set the DLE options
ble_opt_t opt; memset(&opt, 0, sizeof(opt));
opt.common_opt.conn_evt_ext.enable = 1; //DLE err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt); APP_ERROR_CHECK(err_code); opt.gap_opt.ext_len.rxtx_max_pdu_payload_size = NRF_BLE_MAX_MTU_SIZE+4; //DLE err_code = sd_ble_opt_set(BLE_GAP_OPT_EXT_LEN, &opt); APP_ERROR_CHECK(err_code);
I changed ble_nus.h to use the longer MTU size:
*//#define BLE_NUS_MAX_DATA_LEN (GATT_MTU_SIZE_DEFAULT - 3) /< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */ #define BLE_NUS_MAX_DATA_LEN (NRF_BLE_MAX_MTU_SIZE - 3) /< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. /
Any ideas as to why the softdevice would crash on a long write? I get a message saying I have requested the longer MTU by the central as well.
