Dear nodic engineer:
i want test environment temperature with NRF51822 inner temperature module. any information for reference? any temp graph? if need calibration? if need extra temp sensor?
kind regards
kevin
kind regards
kevin
The temperature sensor measures the die temperature of the chip, which may very well be different (higher) than the temperature of the surrounding air. You can refer to the nRF51 Reference Manual for the register interfaces, the nRF51822 Product Specification for electrical specifications.
It shouldn't need any calibration or similar, and is completely internal to the chip.
hi Ole Morten:
thank you for your great support.
i have tested nrf6310\temperature_example. at 30(Celsius)
I checked the data. NRF_TEMP=0x000002AF; TEMP=0xFFFFFFAC;
what's the NRF_TEMP data type? 10bit 2's complement or 32bit 2's complement?
which position is for sign(+/-)?
result=10 = 10* 0.25 celsius.right?
how to work out the result of die temperature?
int main(void) { int32_t volatile temp; int32_t temp_valve;
nrf_temp_init();
nrf_gpio_range_cfg_output(8, 15);
while(true)
NRF_TEMP->TASKS_START = 1;
while ((NRF_TEMP->EVENTS_DATARDY & TEMP_INTENSET_DATARDY_Msk) != (TEMP_INTENSET_DATARDY_Set << TEMP_INTENSET_DATARDY_Pos))
NRF_TEMP->EVENTS_DATARDY = 0;
temp = (nrf_temp_read()/4);
NRF_TEMP->TASKS_STOP = 1; /* Stop the temperature measurement */
nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, (uint8_t)(temp));
nrf_delay_ms(500);
kind regards
kevin chen
from china
