nRF52 app_uart_fifo stops working after an overflow
I am trying to use UART with interrupts and fifo, by using nRF52 SDK 12.2.0 example. It works until the first overflow, after which I cannot any more receive characacters. The related code from SDK is:
    case NRF_DRV_UART_EVT_RX_DONE:
        // Write received byte to FIFO.
        err_code = app_fifo_put(&m_rx_fifo, p_event->data.rxtx.p_data[0]);
        if (err_code != NRF_SUCCESS)
            app_uart_event.evt_type          = APP_UART_FIFO_ERROR;
            app_uart_event.data.error_code   = err_code;
            m_event_handler(&app_uart_event);
        // Notify that there are data available.
        else if (FIFO_LENGTH(m_rx_fifo) != 0)
            app_uart_event.evt_type = APP_UART_DATA_READY;
        // Start new RX if size in buffer.
        if (FIFO_LENGTH(m_rx_fifo) <= m_rx_fifo.buf_size_mask)
            (void)nrf_drv_uart_rx(&app_uart_inst, rx_buffer, 1);
            // Overflow in RX FIFO.
            debugln("rx!");
            m_rx_ovf = true;
            // AFTER THAT, NO MORE CHARACTERS ARE RECEIVED!
How could I recover the UART receiver from the situation? EDIT: The same seems too happen also without any overflow. Then the driver hangs on repeating this driver code fragment on every character:
    case NRF_DRV_UART_EVT_ERROR:
        debug("E");
        app_uart_event.evt_type                 = APP_UART_COMMUNICATION_ERROR;
        app_uart_event.data.error_communication = p_event->data.error.error_mask;
Related question: in the app_uart_fifo there is:
static uint8_t tx_buffer[1];
static uint8_t rx_buffer[1];
On the other hand, there are another buffers made by APP_UART_FIFO_INIT() macro (shown below). The question is how these two (four) buffers are related to each other?
#define APP_UART_FIFO_INIT(P_COMM_PARAMS, RX_BUF_SIZE, TX_BUF_SIZE, EVT_HANDLER, IRQ_PRIO, ERR_CODE) \
    do        \
        app_uart_buffers_t buffers;        \
        static uint8_t     rx_buf[RX_BUF_SIZE];                                                    \
        static uint8_t     tx_buf[TX_BUF_SIZE];                                                    \
        buffers.rx_buf      = rx_buf;                                                              \
        buffers.rx_buf_size = sizeof (rx_buf);                                                     \
        buffers.tx_buf      = tx_buf;                                                              \
        buffers.tx_buf_size = sizeof (tx_buf);                                                     \
        ERR_CODE = app_uart_init(P_COMM_PARAMS, &buffers, EVT_HANDLER, IRQ_PRIO);                  \
    } while (0)
