Is there any way to mitigate delay of redirecting interrupts from softdevice to application? Using nRF51 with S130 there is ~2us delay even with SoftDevice disabled (as stated in SD documentation).
Regards
Regards
Hi Wizath,
If your application requires lower latency, you can think of setting up your application to work as a bootloader. This mean your application/bootloader will receive the interrupt forwarding directly from the MBR, which save you some time because for normal application it will be MBR -> softdevice -> Application.
Please refer to our DFU bootloader to see how it works and how you can forward back the interrupt to the softdevice by initializing it using SD_MBR_COMMAND_INIT_SD MBR command.
