What is the max size of binary file allowed by the free Keil ARM MDK included in SDK 13.0 ?
Some of you may be using the ARM compiler that Nordic provides with SDK 13.0. I was not able to install it on my PC as it does not want to install since it sees another other ARM MDK which I use. I can only compile up to 32 Kb of code with the evaluation compiler V 5.23. How much code can be compiled with the compiler supplied in SDK 13.0? If it is more than 32K, I want to figure out how to get it running.
Mark
