for DFU secure
Hi. I'm using nRF51822AC, SDK12.2.0, S130 v2.0.1.
I made boot secure and application as below. boot.hex, application.hex
Then I made setting file as below.
nrfutil settings generate --family NRF51 --application application.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 bootloader_settings.hex
Then I merged setting file, application, boot as below.
mergehex -m bootloader_settings.hex application.hex boot.hex -o nrf_bootloader_and_app.hex
Then I downloaded Softdevice and nrf_bootloader_and_app.hex using nRFgo studio.
Then I made image file for DFU as below.(application.hex is same as before)
nrfutil pkg generate --hw-version 51 --sd-req 0x87 --application-version 0x13 --application application.hex --key-file priv.pem app_dfu_package.zip
Then I try DFU, it works well.
If I apply new application hex file as below.
nrfutil pkg generate --hw-version 51 --sd-req 0x87 --application-version 0x13 --application new_application.hex --key-file priv.pem app_dfu_package.zip
It doesn't work.
What could be the problem?
Ps. application.hex and new_application.hex files are just application hex file excluding Soft device and boot.
I need your help.
  • Can you update the .zip file you generate from application.hex multiple times ?
    What issue exactly happened when you update the app_dfu_package.zip from new_application.hex ?
    What is the different between new_application.hex and application.hex ?
  • Yes. I can update application.hex multiple times.
    It makes connection and then no progress bar for downloading on smartphone.
    I just added some code for test such as dubug routine. new_application code is from application code.
    Do you think my sequence i did has no problem?
  • We need to check why it doesn't work with your code. A sniffer trace would be very useful.
    I assume that you verified your application works perfectly without the bootloader with the same softdevice.
    in you sequence, the only difference is the hex file. And the bootloader shouldn't have any problem updating different hex.
    There is a chance that your application is too big, have you checked the size of your application ?
  • Thank you very much for your help. I'm gonna check.
