NRF52DK breakpoints in IAR Embedded Workbench
Hi, i just got the tutorial "Getting started with nRF5 DK" with a NRF52DK to run with IAR Embedded Workbench. Unfortunatly i'm not able to set a single breakpoint in the debug mode with IAR. Even in the very baisc spi example is no way to set a breakpoint.
I've tested with Embedded Workbench 8.1 and 7.7 on two computers using nRF5_SDK_12.2.0 with the same result. With Keil uVision5 debugging and setting breakpoins works fine. I would like to use IAR as this is the develoment environment in other projects.
how can i set breakpoints in IAR with j-link/j-trace? thanks
