I ported some SDK code into my device (SDK 10 adapted for S110v7x) where I can successfully Bond my device and use the Services I need (ANCS on my case). I have simplified the example to not use the Whitelist.
The problem occurs when on my iPhone I turn OFF bluetooth (link is disconnected) and turn back ON. The BLE connection is correctly made. When I receive the BLE_GAP_EVT_SEC_INFO_REQUEST, the Device Manager can find the Device and can load bonding information.
But the I receive BLE_GAP_EVT_DISCONNECTED with 0x3D reason -> BLE_HCI_CONN_TERMINATED_DUE_TO_MIC_FAILURE. And I dont understand what could be wrong.
Here's log for first working connection with Bonding :
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_CONNECTED (16)
[DM]: Request to allocation connection instance
[DM]:[00]: Connection Instance Allocated.
[DM]: Searching for device 0xBC 0xDD 0xF1 0x2A 0xB1 0x6B.
[DM]:[DI 0x00]: Device type 0xFF.
[DM]: Device Addr 0x00 0x00 0x00 0x00 0x00 0x00.
[DM]:[DI 0x01]: Device type 0xFF.
[DM]:[DI 0x02]: Device type 0xFF.
[DM]:[DI 0x03]: Device type 0xFF.
[DM]:[DI 0x04]: Device type 0xFF.
[DM]:[DI 0x05]: Device type 0xFF.
[DM]:[DI 0x06]: Device type 0xFF.
[DM]: Notifying application of event 0x11
ANCS : Connected.
[DM]: >> dm_security_status_req
[DM]: << dm_security_status_req
[DM]: >> dm_security_setup_req
[DM]: << dm_security_setup_req, 0x00000000
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_SEC_PARAMS_REQUEST (19)
[DM]: >> BLE_GAP_EVT_SEC_PARAMS_REQUEST
[DM]: Notifying application of event 0x13
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_CONN_SEC_UPDATE (24)
[DM]: >> BLE_GAP_EVT_CONN_SEC_UPDATE
[DM]: --> gatts_context_apply
[DM]:[CI 0x00]: State 0x46, Size 0x00000000
[DM]: Notifying application of event 0x15
ANCS : ANCS ble_evt_dispatch id : BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP (48)
ANCS : ANCS ble_evt_dispatch id : BLE_GATTC_EVT_CHAR_DISC_RSP (50)
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_AUTH_STATUS (23)
[DM]: >> BLE_GAP_EVT_AUTH_STATUS, status 00000000
[DM]: Allocated device instance 0x01
[DM]:[CI 0x00]:[DI 0x01]: Bonded!
[DM]: --> device_context_store
[DM]:[DI 01]:[CI 00]: -> Storing bonding information.
[DM]:pstore bond info, src : 20003820, size : 18, offset : 1c
[DM]: --> gatts_context_store
[DM]: Notifying application of event 0x14
And here's the second connection log, after BLE turned OFF and back ON on the iPhone :
[DM]: Searching for device 0x1A 0x25 0xD4 0x1C 0x96 0x6C.
ANCS : Connected.
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_SEC_INFO_REQUEST (20)
[DM]: >> BLE_GAP_EVT_SEC_INFO_REQUEST
[DM]: Searching for device 0x07 0x00 0x00 0xD1 0x06 0x00.
[DM]: Found device at instance 0x01
[DM]:[00]:[Block ID 0x0003F850]:Loading bond information at 20003820, size 0x00000018, offset 0x0000001C.
[DM]:[0x01]:[0xFF]: Bond context Event
[DM]: Notifying application of event 0x21
[DM]:[00]:Loading service context at 20003838, size 0x00000018, offset 0x00000034.
[DM]:[CI 0x00]:[DI 0x01]: --> gatts_context_load
[DM]:[0x01]:[0xFF]: Service context Event
[DM]: Notifying application of event 0x31
[DM]:[00]:[Block ID 0x0003F850]: Service context loaded, size 0xFFFFFFFF
ANCS : ANCS ble_evt_dispatch id : BLE_GAP_EVT_DISCONNECTED (17)
[DM]: Disconnect Reason 0x003D
We can see here, after loading bond information, the BLE_GAP_EVT_DISCONNECTED with 0x003D reason.
Any idea what could be wrong or missing ? I already looked for other subject about this error, but didn't find anything helpful.
