Can't access variable in IRQ Handler
I'm getting familiar with my nRF52 DK (PCA 10040).
I stumbled on something when I was doing an application that toggles LED1 on every TIMER0 event (200ms). Here is my code
#include "stdint.h"
#include "nrf52.h"
//volatile uint32_t varA;	<POS A>
void initSystem (void) {
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) { }
    NRF_TIMER0->MODE		= 0;
    NRF_TIMER0->BITMODE		= 3;
    NRF_TIMER0->PRESCALER	= 5;
    NRF_TIMER0->CC[0]		= 100000;		// TIMER0_IRQn event each 200ms
    NRF_TIMER0->INTENSET	= (1<<16);
    NRF_TIMER0->TASKS_CLEAR = 1;
    NRF_TIMER0->SHORTS		= 1;
    NRF_TIMER0->TASKS_START = 1;
    NVIC_SetPriority(TIMER0_IRQn, 7);
    NVIC_ClearPendingIRQ(TIMER0_IRQn);
    NVIC_EnableIRQ(TIMER0_IRQn);
int main (void) {
    NRF_P0->DIRSET = (1<<17);
    NRF_P0->OUTSET = (1<<17);
    initSystem();
    while (1) { }
void TIMER0_IRQHandler (void) {
    volatile uint32_t varA;		// <POS B>
    varA = NRF_P0->OUTSET & (1<<17);
    if (varA)
	    NRF_P0->OUTCLR = (1<<17);
    NRF_TIMER0->EVENTS_COMPARE[0] = 0;
Everything is great. But if I move the declaration of the varA to the top (i.e. in my opinion declaring it as a global variable) it does not work. I don't get a compile or link error. The LED just won't toggle.
Why can't I access global variables inside my IRQ Handler??
NOTE: I'm only using CMSIS: Core and Device startup
  • I Rebuild the code, load it to the target using J-LINK / J-TRACE Cortex driver with the option Reset and Run. Then I start the debugger J-Link / J-Trace Adapter with Port = SW @ Max Clock 5 Mhz. I set a breakpoint at "varA = NRF_P0->OUTSET & (1<<17) in the IRQHandler Press Run (F5) and the code stops at the breakpoint. From here I can either press Run again or single step the IRQHandler. In both ways the LED is toggled. When I stop the debugger I'm not sure if the code is still running on the DK because the LED doesn't toggle anymore. Doesn't help if unplug/plug the USB cable. I'm running in evaluation mode if that is a problem? My code is faaaar less than the 32k limit.. Everything is default in my project options except i'm also producing a Hex file and using J-LINK/J-TRACE Cortex driver instead of ULINK Pro Cortex Debugger
