Bonding issue in SDK11 with ANCS
Hi I am using SDK11 with S130, NRF51822 that using ANCS and facing bonding problems after reach the max bonds. Reference to nRF51-ble-peripheral-bond-handling example, I use the ble_app_ancs_c project example and add app_bond.c and app_bond.h to the project.
in main.c add:
#include "app_bond.h"
#include "nrf_nvic.h"
static app_bond_table_t                 m_app_bond_table;
In device_manager_int(), add the followings:
app_bond_init(&m_app_bond_table);
    for(uint8_t i = 0; i < DEVICE_MANAGER_MAX_BONDS; i++)
        printf("[APP][ID: %d], Application context : %08X\r\n",m_app_bond_table.device_id[i],(unsigned int) m_app_bond_table.app_bond_cnt[i]);
in device_manager_evt_handler add the followings:
    static bool device_delete_all_started;
    // Recovery in the event of DM_DEVICE_CONTEXT_FULL
    if(event_result == DM_DEVICE_CONTEXT_FULL)
        /* Clear all devices from the bond table*/
        err_code = dm_device_delete_all(&m_app_handle);
        device_delete_all_started = true;
        APP_ERROR_CHECK(event_result);
    if (p_evt->event_id == DM_EVT_DEVICE_CONTEXT_STORED)
        table_index_t table_index;
        //Find first and last bond created from m_bond_index_table
        app_bond_find(&m_app_bond_table,&table_index);
		//Increment counter if a new bond was created
        if(!(table_index.mr_cnt_val >= m_app_bond_table.app_bond_cnt[p_handle->device_id]))
           table_index.mr_cnt_val++;
           m_app_bond_table.app_bond_cnt[p_handle->device_id] = table_index.mr_cnt_val;
        //Delete first created bond if bond table is full
        if(((table_index.mr_cnt_val-table_index.lr_cnt_val)== DEVICE_MANAGER_MAX_BONDS-1)
             && (table_index.lr_cnt_val != NO_APP_CONTEXT))
                uint32_t err_code;
                dm_handle_t device;
                device.appl_id = 0;
                m_app_bond_table.app_bond_cnt[table_index.lr_index]=NO_APP_CONTEXT;
                device.device_id = m_app_bond_table.device_id[table_index.lr_index];
                err_code = dm_device_delete(&device);
        //Update the app context for new device
        app_bond_update_context(&m_app_bond_table,p_handle);
    else if (p_evt->event_id ==DM_EVT_DEVICE_CONTEXT_DELETED)
         /* Wait for all devices to be cleared before perfoming a sys reset */
         if(device_delete_all_started && (p_handle->device_id == DEVICE_MANAGER_MAX_BONDS -1))
             err_code = sd_nvic_SystemReset();
Disable whitelist in advertising_init(): options.ble_adv_whitelist_enabled = BLE_ADV_WHITELIST_DISABLED ;
In device_manager_peripheral.c
#define DEVICE_MANAGER_MAX_BONDS         4
#define DEVICE_MANAGER_APP_CONTEXT_SIZE    4
Then, I compile and run the program. I bond and remove the bonding with a iPhone over 4 times. ANCS works perfectly. Then I bond this to another iPhone, There is no ANCS response anymore. Open and close the bluetooth setting in iPhone is also same. it stop at notification enable but no ancs:
DB]: Discovery of service with UUID 0xf431 completed with success for Connectionhandle 0
[ANCS]: Database Discovery handler called with event 0x0
[ANCS]: Control Point Characteristic found.
[ANCS]: Notification point Characteristic found.
[ANCS]: Data Source Characteristic found.
Apple Notification Service discovered on the server.
[ANCS]: Enable Notification Source notifications. writing to handle: 31
[ANCS]: Enable Data Source notifications. Writing to handle: 34
Notifications Enabled.
this project is attached. ble_app_ancs_c_try3.zip
It seems the bonding have some problem when it is over the maximum value. I repeat the above procedure in sdk10, it works perfectly. Is there anything I have to add in sdk11 in order to work perfectly?
Thank you.
  • The tutorial is in the youtube introduction in the page I pointed to.
    I don't really get what you meant in your comment. You said if(((table_index.mr_cnt_val-table_index.lr_cnt_val)== DEVICE_MANAGER_MAX_BONDS-1) is executed, meaning dm_device_delete(&device); is called, and it should free up one space in the database, and you should be able to bond with the next device.
    Could you check why it couldn't ?
