BLE _becam can not probably upload application.hex while softdevice is uploaded
Hi I know i have just asked this question 2 days ago. and it works 2 days ago.
Thanks to Terje Schjelderup, he solved my last similar question, and kindly reply my problem. and it was solve
BUT my because my boss borrow my working notebook computer (computer A) to the show for a whille,
so I have to install everything, in my personal notebook computer (computer B) download Keil. 5.. Master control pannel, nRFGo, Jlinker, nrfsdk, packages......
computer A is in win8 , Keil 5 version MDK522
computer B is in win10, Keil 5 version MDK-523
Evaluation board is NRF52 #PCA10400 SDK is nRF5_SDK_12.2.0_f012efa
softdevice hex file I use for upload, is under this directry
nRF5_SDK_12.2.0_f012efa\components\softdevice\s132\hex\s132_nrf52_3.0.0_softdevice.hex
application hex file I use, is under this directry after build ofcourse
...ble_peripheral\ble_app_beacon\pca10040\s132\arm5\_build\nrf52832_xxaa_s132.hex
basically after I installed everthing, it's not function right, in computerB
I mean, In computer B i am not able to use ble_app_becam example to work right i will describe. Computer A works fine, as Terje Schjelderup has helped me in previous quesiton.
AND THE FOLLOWING TRIES ARE ALL IN COMPUTER B.
Try0: blinks works ofcourse!!!!by keil, or by nrfgo, or drag in the hex file directly. all works!!
TRY1:
after press "ERASE ALL", While nrf52 board dont have "SoftDevice" and "Application". I mean when my nrf52 board is clean.
I CAN DOWNLAOD "APPLICATION.HEX" ALONE, either by "Keil download buttom(F8)"
or by nrfGo "Program Application" option.
IT CAN DOWNLOAD "BLE_APP_BECAM" APPLICATION HEX FILE FINE!! BUT AFTER APPLICATION HEX FILE IS DOWNLOADED INTO NRF52 BOARD. THEN SOFTDEVICE HEX FILE NOT ABLE TO UPLOAD.
TRY 2: I know the correct upload order should be 1st "erase all".
2nd "Program SoftDevice"
3rd 3_A:"Program Application" or 3_B "Keil download buttom (F8)"
But!!!! AFTER I DOWNLOAD THE SOFTDEVICE HEX FILE INTO NRF52 BOARD.... IF I TRY using only in nrfGO
3_A:"Program Application" to upload application hex file into nrf52 THEN nrfGO shows me this error message
Application C:/....ble_peripheral\ble_app_beacon\pca10040\s132\arm5\_build\nrf52832_xxaa_s132.hex
programming failed:
This hex file has data in SoftDevice region. Try programming using "SoftDevice", or erase all before programming.
and if I try using keil after Softdevice hex is downlaoded.
3_B "Keil download buttom (F8)" to upload application hex file into nrf52 THEN keil shows me this error message
Error: Flash Downlaod failed- "Cortex-M4"
it's wired, when using Keil to upload application, if SoftDevice hex is not uploaded. Keil can upload application without error message. But if SoftDevice is uploaded. Keil show this error message.
and basically i am stuck here....
Try 3: YES I know there is a very very very easy way to make ble_app_becam all works.... just use the "SD.hex and APP.hex Merge file"
....\nRF5_SDK_12.2.0_f012efa\examples\ble_peripheral\ble_app_beacon\hex\ble_app_beacon_pca10040_s132.hex
and drag into nrf52 board, or upload as application hex file then it works fine!!
but this is way, i cant not learn or modify the code from examples. that's not my question.
basically that's all what i have done. but still struggle
i even try SD132 v 2.01, SD132 V3
and both are not working....
and please help!!!
IN SHORT face this problem how can i upload "softdevie hex" and upload "application hex" either by keil or by nrfGo and can make the ble_app_becom examples works!! thanks for kindly reply
God bless
