Hello, Is it possible to get logs (RTT) from an application started by a bootloader? As of now I don't get anything after the bootloader has jumped to the application start address.
If I run the application separately it works.
Thanks, Jacob
Thanks, Jacob
Hi Jacob,
When I tested here (SDKv13), it seems that when we reinit the log module we will actually open another RTT channel.
So if I open RTT client when the application running, I can only capture the RTT log from the application, even if I reset the device and the device enter the bootloader before it get to the application.
If I open RTT client when the bootloader is running and enterred bootloader mode, then I can follow the RTT client of the bootloader.
Do you really need RTT to be ON on the bootloader ? If you turn it off can you get RTT log on the application ?
