hai
i am working with nrf51822 and mbed.
in my application i have requested one page in flash for data store using pstorage.
pstorage_module_param_t param;
param.block_size = 1024;
param.block_count = 1;
param.cb = cb_handler;
retval = pstorage_register(¶m, &base_handle);
then i stored a value using
retval = pstorage_store(&base_handle, source_data, sizeof(source_data),0)
noe the starting address of my page is 0x0003f800
and the data is stored successfully.
after that i have initialised bonding using security manager
ble.init();
ble.securityManager().init(enableBonding, requireMITM, SecurityManager::IO_CAPS_DISPLAY_ONLY,PASS_KEY);
ble.securityManager().onPasskeyDisplay(passkeyDisplayCallback);
ble.securityManager().onSecuritySetupCompleted(securitySetupCompletedCallback);
and i bonded my phone with my nrf51822. the security bonding is successfully established. now the data i have stored is overwritten by the bonding information. that is the bonding information are stored at the beginning of my page.
after that i have changed PSTORAGE_MAX_APPLICATIONS = 4
in pstorage_platform.h then requested 4 pages for data storage in flash
param.block_count = 4;
now the starting addresses are 0x000ec00 , 0x0003f00 ,0x0003f400 , 0x0003f800
respectively .
after that each time a new device is bonded, the bonding information are stored at the starting of each page.
so my question is can i allocate a separate memory block for bonding information so that i can prevent my data in flash from overwrite..?
edit:-
i have changed PSTORAGE_MAX_APPLICATIONS = 5
and requested only one block for my data.
and i stored my data at an offset of 0x220
retval = pstorage_store(&handle2, source_data, sizeof(source_data),0x220);
now the data is stored in flash with starting address 0x0003fa20. and the bonding information is again stored at the staring of my page.
edit :-
i have tried bonding without pstorge but i cant bond more that two devices . and the bonding information is stored in same page . the staring address is 0x0003f800. the if a third device is bonded some times the system gets hang or the device is to be paired with each connection.
