How can I use ANT serialization(connectivity board and application board)
hello,I'm having a problem with the ANT application,I have two pieces of the PCA10040 board as a ANT connectivity board for a ANT application board.According to the instructions I use SDK13 in two applications.link text image description image description
I open the Connectivity Example from the following directory: nRF5_SDK_13.0.0_04a0bfd\examples\connectivity\experimental_ant\pca10040\ser_s212_uart\arm5_no_packs. I have down ANT_s212_nrf52_2.0.1 and put it in the right place,but when compiling a mistakes: Error: L6218E: Undefined symbol sd_ant_channel_open_with_offset (referred from conn_mw_ant.o).
I open the Application Example from the following directory: nRF5_SDK_13.0.0_04a0bfd\examples\ant\ant_io_demo\ant_io_tx\pca10040\ser_s212_uart\arm5_no_packs when compiling a mistakes: ._build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol sd_ant_channel_open (referred from ant_io_rx.o).
so what should I do? How do I get these two functions: sd_ant_channel_open_with_offset and sd_ant_channel_open .
Thanks, sillysg
  • SDK 13.0.0 is compatible with S212 v4.0.0, not v2.0.1. It seems like Dynastream hasn't released v4.0.0 yet. It should be available here when it is.
    If you want more information I think you must contact them.
  • This seems unreleated, so please add it as a new question. If I answered your question I would appreciate if you would accept it by clicking the grey circle next to it.
