eclipse include path added, but still can't find nrf_error.h?
I am able to use eclipse to run simple project, but after move the real one, getting lost of errors:
www.dropbox.com/.../Screenshot 2014-04-02 09.10.41.png
I add required include path include/s110, but still complain can't find it,
any helps are appreciated
  • when I debug I get errors, I already run the ./disable_cdc.sh and follow steps in gnuarmeclipse.livius.net/.../
    SEGGER J-Link GDB Server V4.84 Command Line Version
    JLinkARM.dll V4.84 (DLL compiled Mar 28 2014 16:35:10)
    -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: on Silent mode: off Single run mode: on Target connection timeout: 5 sec. ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: nRF51822_xxAA_s110 Target interface: SWD Target interface speed: 30kHz Target endian: little
    Connecting to J-Link... J-Link is connected. Firmware: J-Link OB-SAM3U128 V1 compiled Dec 11 2013 20:20:11 Hardware: V1.00 S/N: 480205216 Checking target voltage... Target voltage: 3.30 V Listening on TCP/IP port 2331 Connecting to target...ERROR: Could not connect to target. Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    do I need to restart machine? in the same machine with fusion, I could debug with keil
