eclipse include path added, but still can't find nrf_error.h?
I am able to use eclipse to run simple project, but after move the real one, getting lost of errors:
www.dropbox.com/.../Screenshot 2014-04-02 09.10.41.png
I add required include path include/s110, but still complain can't find it,
any helps are appreciated
  • very strange, I can only comment, can't reply, reply will not show up
  • Unfortunately I don't know any book but you can find plenty of information on Internet.
    The real size is shown at the end of compilation. The file size .elf or .hex are not relavant for comparaison. Everything also depends optimization setting of each compiler.
    The debugger issue seem to be the problem with your board. Are you using the eval board or your own. If you use the Eval board, check the with J-Link OB. Make sure it's in the ON position.
  • I can debug in keil, so the Eval board 's J-Link OB should be ok?
  • I have no clue on this one. I though you already has the debugger working in one of the thread you posted sometimes ago. What is different now ?
  • after I set back to windows, and switch back, the debugger works now
    SWO disabled succesfully. ERROR: Could not detect CPU clock speed. Verification of test code downloaded into RAM failed.
    Failed to enable SWO. Could not measure target CPU frequency. Read 4 bytes @ address 0x00012B98 (Data = 0x681B4B15) Downloading 16192 bytes @ address 0x00014000 - Verify failed Downloading 15968 bytes @ address 0x00017F40 - Verify failed Downloading 16160 bytes @ address 0x0001BDA0 - Verify failed Downloading 16096 bytes @ address 0x0001FCC0 - Verify failed Downloading 16080 bytes @ address 0x00023BA0 - Verify failed Downloading 16176 bytes @ address 0x00027A70 - Verify failed Downloading 12208 bytes @ address 0x0002B9A0 - Verify failed Downloading 68 bytes @ address 0x0002E950 - Verify failed Downloading 8 bytes @ address 0x0002E994 - Verify failed Downloading 2396 bytes @ address 0x0002E99C - Verify failed Writing register (PC = 0x0002e951) Read 4 bytes @ address 0x0002E950 (Data = 0xFFFFFFFF) Read 4 bytes @ address 0xFFFFFFFF (Data = 0x001C4800) Read 4 bytes @ address 0xFFFFFFFF (Data = 0x001C4800) Resetting target Halting target CPU... ...Target halted (PC = 0x00012B98) R0 = FFFFFFFF, R1 = FFFFFFFF, R2 = FFFFFFFF, R3 = FFFFFFFF R4 = FFFFFFFF, R5 = FFFFFFFF, R6 = FFFFFFFF, R7 = FFFFFFFF R8 = FFFFFFFF, R9 = FFFFFFFF, R10= FFFFFFFF, R11= FFFFFFFF R12= FFFFFFFF, R13= 20001C48, MSP= 20001C48, PSP= FFFFFFFC R14(LR) = FFFFFFFF, R15(PC) = 00012B98 XPSR C1000000, APSR C0000000, EPSR 01000000, IPSR 00000000 CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00 Reading all registers Read 4 bytes @ address 0x00012B98 (Data = 0x681B4B15) Starting target CPU... Debugger requested to halt target... ...Target halted (PC = 0x0000FE3E) Reading all registers Read 4 bytes @ address 0x0000FE3E (Data = 0xBF20BF40) Read 4 bytes @ address 0x0000016A (Data = 0x9801B401) Read 4 bytes @ address 0x0000016A (Data = 0x9801B401)
    however, it can't stop at any break point, the board seems ok to run, just can't stop https://www.dropbox.com/s/v1xe3gvz8hm1w9t/Screenshot%202014-04-10%2017.08.08.png
