nrf51822 advertising packet not detected
I would like to ask your support for a very unusual problem that I'm facing with a project based on nrf51822.
The board under test is based on nrf51822, SDK12.1, softdevice S130. The nordic example used for testing is the Nordic HRM.
The advertising works perfectly with 5 different smartphones (different brands), with 2 laptops (internal BT chip) and is always recognised by the nordic sniffer.
Two tablets, an Asus zenpad 10 and a kindle fire HD do not identify any advertising packet. This is true both using android bluetooth discovery and the nrf-connect application (same version and settings on all mobile devices).
On the other side, the same two tablets are able to discover the advertising packets both on a PCA10028 and on a PCA10031 (using the same code and softdevice hex).
The packets recorded by the nordic sniffer are identical (except for the BLE address). Even setting explicitly on the board under test the BLE address to one of the eval board didn't resolve the problem.
Could you help me in understanding the source of the problem and how to address it?
  • FormerMember
    0 FormerMember
    My suspicion is that the problem is related to an offset of the carrier frequency: The carrier frequency output from the radio is heavily dependent on the value of the load capacitors used with the 16 MHz crystal.
    On your custom board:
    • Which 16 MHz crystal do you use?
    • What is the load capacitance of that crystal?
    • What is the value of the load capacitors used? Is their value calculated according to the formula in the "Crystal and load capacitors" section in this tutorial?
    Do you have access to a spectrum analyzer? If so, could you use the radio_test example in the SDK to check the offset of the carrier frequency?
  • FormerMember
    0 FormerMember
