Is it possible NRF52 NUS service and Buttonless DFU service work together like the given example, ble_app_hrs, s132_with_dfu?
I was trying to add buttonless DFU service along with NUS service. I used SDK v11. Taken the example ble_app_hrs, s132_with_dfu. And added my existing NUS service. I faced a problem that, both are not working together. If i completely disable DFU, NUS service is working. What I should do to make both working together. Any sample code, with NUS and DFU working together?
Thanks in Advance.
Praveen
  • FormerMember
    0 FormerMember
    There are a few things you could check:
    • The number of custom UUIDs set in the application.
    • The required RAM (sd_softdevice_enable() ).
    • (The attribute table size. Does it change anything if it is increased?)
  • Using nrf connect app, I can just connect it. Showing UART and DFU service. I can't send or receive any data. The advertising LED is keep on running. And suddenly mobile app getting disconnected. Connection not establishing properly.
