how to handle TWI and PWM library same time
Hi, i am using Nrf52 DK board and i am working on TWI to get accelerometer(MMA7660) values using TWI driver. so that i am getting accelerometer values and Tap information and i am able to print this info on UART.
in this process i have initialized and enabled PWM(integrated PWM Library example) by taping Button1. if i start the PWM i am able to print and observe duty cycle values on UART but Accelerometer is stoping. how i can TWI and PWM parallelly.
my aim is i need to run both TWI and PWM same time. if i TAP on accelerometer i need to print exact duty cycle value on UART, but at a time i unable to run Both. Thank you.
This is the Code:
	uint32_t err_code;
	bool erase_bonds;
	// Initialize.
	buttons_leds_handler_init(&erase_bonds);
	uart_handler_init();
	ble_stack_handler_init();
	ble_advertising_start(BLE_ADV_EVT_FAST);
	printf("Starting low power working on\r\n");
	MMA7660_init();
	//i2cHandler_init();
	for(;;){
		low_power_manager();
		///Accelerometer....
		uint8_t reg = 0;
		nrf_delay_ms(10);
		/* Start transaction with a slave with the specified address. */
		err_code = nrf_drv_twi_tx(&m_twi_mma_7660, MMA7660_ADDR, &reg, sizeof(reg), true);
if(err_code != NRF_SUCCESS){
		printf("ACCELEROMETER ERROR\r\n");
	if(is_ButtonTapeOccured()){                 /// true if i TAP button on DK board..
				                                        //  app_pwm_channel_duty_set(&pwm_library, 0, 100);
				start_PWM();                     ///started PWM  at pin NUM ARDUINO_13_PIN i.e P0.25
