i was just wondering as we dont need the high clock rate whether its possible to run the nrf52832 with less than 64 Mhz by replacing the 32 mhz crystal with a different crystal with a lower clock frequency?
thank you :)
thank you :)
We will in the future, yes. It is needed for that? (have not yet looked into BLE in detail) If so then my this settles this, haha.
You can only run the CPU at 64MHz. Using a 64MHz clock will execute your tasks faster and overall you wont save power reducing the clock speed. It is therfore not implemented any options to use a different clock frequency for the CPU. If you are using BLE, you have to use an external 32 MHz crystal with a frequency tolerance of max 40 ppm.
Thank you very much!
