Compiling code
I got pca10040 dk and I am trying to run the code that was sent to me earlier by one of nordic employee. I could compile it without errors but I cant see any advertising data in the nrf connect app.
I am using nrf52 now and sdk 12.2.0.
I have made a case and my case and case number is 34506. I am posting here because I am getting faster response here.
The soft device that I am using is C:/Users/Ambimat/Desktop/abcd/components/softdevice/s132/hex/s132_nrf52_3.0.0_softdevice.hex
Shailav
  • You haven't posted much information to enable people to help too much but this might be of use:
    1. Have you loaded the correct Soft Device?
    2. Have you double checked your memory settings? Because your code compiles doesn't mean you don't have an issue here.
    3. In debug mode you should be able to halt your code to see if you are in an error loop. Else in main before your loop set breakpoints at each step to see which call is causing the issue.
    These would be the first three things to do.
  • The soft device that I am using is C:/Users/Ambimat/Desktop/abcd/components/softdevice/s132/hex/s132_nrf52_3.0.0_softdevice.hex Thanks, Shailav
    From the build-log in the project you uploaded, you have the following linking error:
    linking...
    .\_build\nrf52832_xxaa.axf: error: L6050U:
    The code size of this image (52380 bytes) exceeds the maximum allowed for this version of the linker.
    Finished: 0 information, 0 warning, 0 error and 1 fatal error messages.
    ".\_build\nrf52832_xxaa.axf" - 1 Error(s), 0 Warning(s).
    The evaluation version of Keil does not support program size of more than 32 kB. So you will have to buy a Keil license if you want to build projects above 32 kB with Keil.
    The other alternative is to switch to build tools that are not size limited, such as GCC or Segger Embedded Studio. You can find a tutorial on setting up GCC with Eclipse here, and a guide for setting up Segger Embedded Studio here.
  • Hello, Yes in the keil I am getting that error but I am using armgcc make file to build. I am uploading my code to controller via cmd line using command nrfjprog --family <nRF51/52> --program _build/.hex So code size is not a problem for me. Thanks
