I'm currently trying to use the database discovery module to get the total number of services and the number of discovered services so that I know when all of the services for a particular peripheral device are discovered and set up before discovering the next device. I'm doing this because from what I've found, you can't do things like sd_ble_gattc_write while a discovery is in progress.
The issue is that the srv_count and discoveries_count fields in ble_db_discovery_t don't seem to be updated correctly. The srv_count field is always zero, in fact I don't see it referenced anywhere but where it is defined in ble_db_discovery.h, and discoveries_count seems to be one less than the number of services registered using ble_db_discovery_evt_register
Am I missing something? Is there another way I can check if all the services have been discovered?
The services field is updated so I can iterate through that array to get total number of services and manually keep track of discoveries using the BLE_DB_DISCOVERY_COMPLETE event but, it would be nice to get my code working with the database discovery module
I'm using SDK v12.1 with a NRF52
EDIT 13 April 17
To add to this, the BLE_DB_DISCOVERY_AVAILABLE event is never triggered in db_discovery. I've fixed it as shown below. It's not thoroughy tested but, works so far. I've added it because the BLE_DB_DISCOVERY_COMPLETE event is generated before discovery_in_progress is set to false so, when i receive BLE_DB_DISCOVERY_AVAILABLE, i can start discovery of the next pending connection
diff --git a/v12.1/ble/ble_db_discovery/ble_db_discovery.c b/v12.1/ble/ble_db_discovery/ble_db_discovery.c
index ab9e98d..df43c0c 100644
--- a/v12.1/ble/ble_db_discovery/ble_db_discovery.c
+++ b/v12.1/ble/ble_db_discovery/ble_db_discovery.c
@@ -146,6 +146,27 @@ static void discovery_error_evt_trigger(ble_db_discovery_t * const p_db_discover
+static void discovery_available_evt_trigger(ble_db_discovery_t * const p_db_discovery,
+ uint32_t err_code,
+ uint16_t const conn_handle)
+ ble_db_discovery_evt_handler_t p_evt_handler;
+ ble_gatt_db_srv_t * p_srv_being_discovered;
+ p_srv_being_discovered = &(p_db_discovery->services[p_db_discovery->curr_srv_ind]);
+ p_evt_handler = registered_handler_get(&(p_srv_being_discovered->srv_uuid));
+ if (p_evt_handler != NULL)
+ ble_db_discovery_evt_t evt;
+ evt.conn_handle = conn_handle;
+ evt.evt_type = BLE_DB_DISCOVERY_AVAILABLE;
+ p_evt_handler(&evt);
/**@brief Function for triggering a Discovery Complete or Service Not Found event to the
* application.
@@ -258,9 +279,11 @@ static void on_srv_disc_completion(ble_db_discovery_t * p_db_discovery,
// Error with discovering the service.
// Indicate the error to the registered user application.
discovery_error_evt_trigger(p_db_discovery, err_code, conn_handle);
+ discovery_available_evt_trigger(p_db_discovery, false, conn_handle);
- m_pending_user_evts[0].evt.evt_type = BLE_DB_DISCOVERY_AVAILABLE;
- m_pending_user_evts[0].evt.conn_handle = conn_handle;
+ //m_pending_user_evts[0].evt.evt_type = BLE_DB_DISCOVERY_AVAILABLE;
+ //m_pending_user_evts[0].evt.conn_handle = conn_handle;
// m_evt_handler(&m_pending_user_evts[0].evt);
return;
@@ -270,8 +293,9 @@ static void on_srv_disc_completion(ble_db_discovery_t * p_db_discovery,
// No more service discovery is needed.
p_db_discovery->discovery_in_progress = false;
//m_evt_handler(&m_pending_user_evts[0].evt);
@@ -552,8 +576,9 @@ static void on_primary_srv_discovery_rsp(ble_db_discovery_t * const p_db_disc
err_code,
p_ble_gattc_evt->conn_handle);
- m_pending_user_evts[0].evt.conn_handle = p_ble_gattc_evt->conn_handle;
+ discovery_available_evt_trigger(p_db_discovery, false, p_ble_gattc_evt->conn_handle);
+ //m_pending_user_evts[0].evt.conn_handle = p_ble_gattc_evt->conn_handle;
@@ -657,8 +682,9 @@ static void on_characteristic_discovery_rsp(ble_db_discovery_t * const p_db_d
err_code,
return;
@@ -690,8 +716,9 @@ static void on_characteristic_discovery_rsp(ble_db_discovery_t * const p_db_d
err_code,
return;
@@ -790,8 +817,9 @@ static void on_descriptor_discovery_rsp(ble_db_discovery_t * const p_db_disco
err_code,
return;
