how can I get write event?
Hi. I'm using nRF52832, SDK13, S132v4.0.2.
I'm making peripheral device using nRF52832. And I can see it gets BLE_GATTS_EVT_WRITE event as below when central sends WRITE event.
static void on_ble_evt(ble_evt_t * p_ble_evt) { ...... switch (p_ble_evt->header.evt_id) { ...... case BLE_GATTS_EVT_WRITE: { } } }
How can I get event When central sends "write no need response"? As I tested I can't get the event using "BLE_GATTS_EVT_WRITE".
I hope your reply.
  • Hi Roger,
    You should have BLE_GATTS_EVT_WRITE when the central do a write command (write without response). As you can find in the paremeter for the event inside ble_gatts_evt_write_t we have an .op , meaning the type of operation. And in BLE_GATTS_OPS list you can find write request and write command there.
    We need to look at how you define your characteristic, if you allow write command or not ? When you do write command do you see the actual value was updated ?
  • Thanks a lot. After I added code as below, it works well. char_md.char_props.write_wo_resp= 1;
    Thanks again.
