Hi
i am trying to connect ble_app_proximity with ios (10.0.2), but every time it is generating PM_EVT_CONN_SEC_FAILED for pm_evt_handler with sdk 12.2.0
i need to implement whitelist functionality once device is connected.
Thanks
Hi
Thanks
It's up to the application if you want to allow re-bonding or not. If you have a look at pm_evt_handler() in main.c in our examples you can find this:
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
Set it to true will allow rebonding.
But be aware that this may open a security hole that attacker can pretend to be your master and bond with your device as if your master has deleted the bond info and trying to rebond. He then can replace the old bond with the new one. And next time when your master want to connect, it will have to do a new bond and give a chance for attacker to sniff the bond information.
} break;
