Data base discovery fails for vendor specific service when DFU included
Edit 1
To narrow down I did this... Below is ble_dfu_init() from ble_dfu.c.
uint32_t ble_dfu_init(ble_dfu_t * p_dfu, const ble_dfu_init_t * p_dfu_init)
    uint32_t      err_code;
    ble_uuid_t    ble_uuid;
    ble_uuid128_t nus_base_uuid = BLE_DFU_BASE_UUID;
    VERIFY_PARAM_NOT_NULL(p_dfu);
    VERIFY_PARAM_NOT_NULL(p_dfu_init);
    p_m_dfu = p_dfu; // TODO: find a nicer solution to this
    // Initialize the service structure.
    p_dfu->conn_handle             = BLE_CONN_HANDLE_INVALID;
    p_dfu->evt_handler             = p_dfu_init->evt_handler;
    p_dfu->is_waiting_for_disconnection = false;
    p_dfu->is_ctrlpt_notification_enabled = false;
==>5
    /**@snippet [Adding proprietary Service to S110 SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_dfu->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_dfu->uuid_type;
    ble_uuid.uuid = BLE_UUID_DFU_SERVICE;
==>4
    // Add the service.
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_dfu->service_handle);
==>3
    // Add the RX Characteristic.
    err_code = rx_char_add(p_dfu, p_dfu_init);
==>2
    err_code = nrf_dfu_flash_init(true);
==>1
    nrf_dfu_settings_init();
    return NRF_SUCCESS;
Keeping the #endif at the same location I kept moving #if 0 from 1 till 5. Till 4, service discovery for my custom service fails. At 5, Eureka!! My custom service is detected.
Why sd_ble_uuid_vs_add() for DFU is interfering with my custom service detection? I guess there is some problem with sd_ble_uuid_vs_add(), can someone please prove me wrong?
Original question
I have a vendor specific service and DFU service included in my application. When service discovery begins for vendor specific service it arrives at the below point in on_primary_srv_discovery_rsp()
    ==>NRF_LOG_INFO("Service UUID 0x%x Not found\r\n", p_srv_being_discovered->srv_uuid.uuid);
    // Trigger Service Not Found event to the application.
    discovery_complete_evt_trigger(p_db_discovery,
                                   false,
                                   p_ble_gattc_evt->conn_handle);
    on_srv_disc_completion(p_db_discovery,
The response in p_ble_gattc_evt->gatt_status is 0x010athat is BLE_GATT_STATUS_ATTERR_ATTRIBUTE_NOT_FOUND.
But when DFU service is removed then my application works fine. Also, during initialisation, DFU service is getting initialised first and later vendor specific service is initialised. When I change the sequence of initialisation, the vendor specific service works fine but db discovery for DFU fails now.
Note that I have made vs_uuid_count=2 in softdevice_handler.c and I have also changed the app_ram_base in my linker file accordingly.
Is this a known issue?
  • FormerMember
    0 FormerMember
    Do you have checked using nRF Connect (PC/Android/iOS) that the NUS service actually is there?
  • I am using NRF connect to test my application. I can see the DFU service as well as the custom service when I connect to my device using NRF connect mobile app. I have also added my custom service in NRF mobile app.
  • FormerMember
    0 FormerMember in reply to FormerMember
    Okay, I see. How do you add the NUS service in the central and peripheral side of the link? Do you use sd_ble_uuid_vs_add?
  • I am using sd_ble_uuid_vs_add() and then sd_ble_gatts_service_add() on the peripheral side to add my custom service.On the central side, I use the NRF connect app and just copy my peripheral service into the NRF connect app.
    And for initialising DFU service I am using ble_dfu_init() from ble_dfu.c from sdk 12.0.0.
  • FormerMember
    The reason that "step 5" is necessary is because in that step, the custom UUID is being added to the softdevice.
1 2
