easyDMA and TWI(_app)
Hello everyone
I was not able to find any explicit statement regarding the use of the TWI_APP with easyDMA on the nRF52 series and SDK13.0.0.
I checked the examples linked here (direct link to examples GitHub folder), which are based on the SDK11.0.0.
I want to read two sensors via TWI without the use of the CPU, i.e. I would like to have a GPIOTE from one sensor, which triggers the readout via TWI of both sensors with easyDMA thanks to the PPI. Thus, apart from having another (newer) SDK as starting point and having more than one sensor, my situation is fairly similar to the one shown in the example /nrf5-mpu-examples-master/nrf52-mpu-easydma-using-gpiote-and-registers/.
I see that one has to "manually" set up the TWI. Also, the HW address is bound to the TWI instance
NRF_TWIM0->ADDRESS = MPU_ADDRESS;
Also, I read this thread, but I still do not have all information I am looking for. Also, in the proposed solution it is suggested to use the nrf_drw_twi directly, and not the app_twi, but I would prefer to be able to stick with the app_twi as what I have done so far for my setup uses this library.
So I have the following questions:
  1. How does the TWI_APP fit into this picture? Is there any relation between app_twi_schedule() and interrupt-based TWI?
  2. Can you use easyDMA alongside the TWI_APP? If so, is there any example I missed?
  3. If I have to follow the example of which above and set up the TWI manually, i.e. step by step by setting all registers myself without the aid of auxiliary wrapper functions, is there a way of reading multiple sensors using only one TWI instance or do I need to use more than one TWI instance?
  4. If you use the approach described here, how do you decide on the RAM address? Can you choose any of the valid without considering anything else?
Thank you in advance for your help!
Ale
