hello, how to program nrf51822 from the beginning.. i am having nrf51822 evaluation kit .and SEGGER J-link LITE cortexM REV8.1 module..
please help
please help
Hi Vijay
I am a little confused. In your text you say that you have the evaluation kit but your attached image shows the development kit.
If you have the development kit, you ideally need to to have the nRFgo kit also. Then you should follow the Quick start chapter in the nRF51822 Development Kit User Guide v1.4, available on our web site.
However, it is not mandatory to have the nRFgo kit in order to operate the PCA10004/PCA10005 boards of the development kit. You could supply 3.3V to pin 2 on header K1 with an external power supply and also connect the ground of the power supply to the GND contact on the P5 pad. Then you should be able to program the nRF51822 and debug it. With the nRFgo kit however, you will have leds, buttons, GPIO headers, etc.
If you have the evaluation kit, then you do not need any additional hardware and should be good to go. Just follow the Quick start chapter in the nRF51822 Evaluation Kit User Guide v1.2, available on our web site.
More about the development kit and evaluation kit on this thread.
hello, according to your reply ,i have connected j-link LITE CORTEX M AND PCA10004 .and given 3.3V to the pca1004 externally.but still it is not getting detect .i am attaching the image.
thank you
Are you sure you have the power connected correctly?
I am running a devkit 51422. This gives the output as in the screenshot. I give power 3.3V to P2:1,2,3,4 and GND to P2:37,38,39,40. It looks you dont have power connected.
I have problems flashing this Development kit from Keil Evaluation IDE. Whereas flashing an 51822 Evaluation Kit works.
When I open the JLink console which commands to I have to execute in order to properly flash my application blinky_arm.bin? Is a
device nrf51422 loadbin blinky_arm, 0 sufficient?
Adib.
hello, now it is getting detected but showing error like sw device is not found in keil.what to do now ?? in keil it is showing following error showed in image
hi, and also i am getting the following error.. please help.
